Aussie ‘E-Max’ style T/A Challenger
Author Topic: Aussie ‘E-Max’ style T/A Challenger  (Read 24240 times)
Offline YellowThumper
  • I left the snow for this?
Re: Aussie ‘E-Max’ style T/A Challenger
« Reply #45 on: January 03, 2017 - 12:04:08 AM »
 :2thumbs:
Offline AU6pack
« Reply #46 on: January 11, 2017 - 01:17:49 AM »
Engine finally on dyno. 537 ft lb & 524 hp  :clapping:
What do you think of those numbers? Would have expected more like 550/550 with the work done, but overall I'm pretty happy with the result.
Video here - https://www.youtube.com/watch?v=4p5tJCeaa8Y&feature=youtu.be
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline 67vertman
  • Member since 9-23-2005
« Reply #47 on: January 11, 2017 - 10:32:07 AM »
Those are very decent numbers for a street motor.  :2thumbs:
With dual guads or a bigger four barrel I bet you could make more power.
Offline AU6pack
« Reply #48 on: January 31, 2017 - 12:34:09 AM »
Finally got the front and rear suspension in the car after spraying the underside. The Hotchkis and QA product is top notch quality and everything bolted up perfectly. I hope it handles as good as it looks!
Not many pictures of the rear as we were racing the clock to get out of the shop. The rear sway bar took a few hours as the brackets needed to be welded to the frame. Car comes home next Tuesday after 2 years at my mates shop. Looking forward to working through the long to do list at my pace....
Craig
Offline MoparCar
« Reply #49 on: January 31, 2017 - 08:01:10 AM »
Looks great! Did you shorten the steering shaft for the u-joint to Borgeson box? Nice job!
Wes
« Reply #50 on: January 31, 2017 - 08:02:06 AM »
That's quite the mounting angle on the steering box?  :clueless: Is the center link/steering wheel able to be centered in the car with the box on an angle like that?
« Last Edit: January 31, 2017 - 08:05:29 AM by brads70 »
Offline AU6pack
« Reply #51 on: January 31, 2017 - 06:32:16 PM »
Hi Brad. It does have quite an angle but it all bolted up without any difficulty. I will check it properly next week - and may be asking some dumb questions then...
Craig
Offline AU6pack
« Reply #52 on: January 31, 2017 - 06:34:30 PM »
Wes
Thanks Wes. Yep had to cut about an inch off the shaft. It is much smaller and lighter than the original unit. Anyone got any feed back on the Borgeson box? I'm kinda mad I didn't go with Rack & Pinion now though.
Craig
Offline AU6pack
« Reply #53 on: January 31, 2017 - 06:49:25 PM »
Got the car on the ground. There appears to be a honking horizontal gap below the bumper and the rear valance. It looks big, black and crappy  :22yikes:
Checking out other cars on the net it looks like there is a factory gap, but nothing like what I've got. Further tweaking closed it up about 1/2" more but it still looks bad.
Anyone got a pic of theirs or can shed some light on why my gap is like the Grand Canyon?
Craig
« Reply #54 on: January 31, 2017 - 07:11:04 PM »
I suspect your using a repop bumper. They are bowed. I did too and noticed its not the same an the originals . I noticed it looking at the gap/distance from the bumper to the bottom of the tail lights .
 Its closer in the middle ( reverse lens ) then the gap gets bigger as you get towards the outside. This " flaw" also effects how the bumperetts fit . Drives me nuts I think at some point I'll get my original re-chromed.  :pullinghair:
« Reply #55 on: January 31, 2017 - 07:15:53 PM »
The pitman arm and idler arm needs to be parallel in order for the steering geometry to work best.
Offline MoparCar
« Reply #56 on: January 31, 2017 - 07:59:43 PM »
Brad, when you say parallel which plane are you referring to? Top view or side? Do you mean if looking at the side view the angle of the splined steering sector needs to be the same as the centerline of the mount on the idler or are you referring to more or less a top view meaning they need to be parallel side by side? I hope that makes sense.
Thanks, Wes
Offline GoodysGotaCuda
« Reply #57 on: January 31, 2017 - 08:22:38 PM »
Thanks, Wes
Sideview. The Pitman Arm and Idler need to be parallel with the Y-axis of the car.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #58 on: January 31, 2017 - 08:53:44 PM »
Thanks, Wes
Top view, looking from above down into the engine bay.
« Reply #59 on: January 31, 2017 - 09:05:14 PM »
I was looking for a picture to show you  and came across this article. http://www.hotrod.com/articles/1973-dodge-challenger-project-slick-qa1-suspension-upgrade/
I'm thinking that angle of your steering box is going to cause you problems. I'm guessing it from the new steering box that the mounting plate was welded on out of position. From what I've read online is a common issue with these boxes. One of the reasons I don't have one.... I've never heard of an issue but I'm not that trusting of welding the mounting plate on such an important part as a steering box. But thats just me.....
