Author Topic: Speedhut gauge wiring help  (Read 2809 times)
Offline dave73chally
« on: June 16, 2016 - 09:54:46 PM »
Getting ready to install speedhut gauges in my 73 challenger with standard dash. Here's the wiring diagram I drew up, tell me what's wrong as I'm sure something is...
« Last Edit: June 17, 2016 - 11:56:06 AM by dave73chally »
73 Challenger
Re: Speedhut gauge wiring help
« Reply #1 on: June 18, 2016 - 09:20:53 AM »
Anyone?
73 Challenger
Offline GoodysGotaCuda
« Reply #2 on: June 18, 2016 - 01:58:42 PM »
I'm not sure why the volt gauge would need four wires off of it. It should just be switched 12v, ground and lighting.
What is the "fuel sender" ground wire doing for you? Are you using a factory sending unit?
The grey wire for lighting, the "speedhut lighting dial" does what? I assume if it's some form of dimmer it would need to go before [in series] all of the other light circuits and not in parallel to the circuit. But that's a guess, i'm not familiar with it.
Does the speedo need constant power for keeping settings?
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: June 18, 2016 - 02:46:33 PM »
- a red wire is 12v keyed ignition for main gauge power, black is ground, white is 12v dash lighting for the needle lighting, yellow is listed as the 12v power source. Fwiw, all the speedhut gauges I got have the red, white and black wires. They supplied a 'harness' that connects all these wires together for all the gauges.
-yes, factory sending unit. Am I grounding this properly?
- speedhut provided their own dimmer switch which I'm guessing will take place of the stock dimmer switch? So I. terms of wiring, do I take the orange input wire to the stock dimmer end hook that up to the grey speedhut dimmer. Then separately, the gauge lighting wires into the orange output to the stock gauges?
-that and to help the speedo acquire a gps signal faster. With it, speedhut claims it will almost instantaneously have a signal, without it, may take up to 2 minutes.
73 Challenger
« Reply #4 on: June 18, 2016 - 03:02:09 PM »
Quote
I presume you are. The sending unit needs to have a good chassis ground.
Quote
I would need to see their diagram for that component to address the question.
[/quote]
1976 Dodge Warlock
Offline lulurocks
« Reply #5 on: June 18, 2016 - 03:56:26 PM »
Pm sent
« Reply #6 on: June 18, 2016 - 04:46:30 PM »
73 Challenger
« Reply #7 on: June 20, 2016 - 08:49:59 AM »
After speaking to lulurocks, here is my updated diagram:
Thanks again!
73 Challenger
