Author Topic: Lifting front end of e-bodies, safest way?  (Read 1357 times)
Offline Fish Tale
« on: June 18, 2016 - 04:29:11 PM »
Just want to make sure I am safely lifting and supporting the front end as I work underneath.  Where do you guys place the floor jack and jack stands?  Rear end makes sense but front end can have multiple positions.
71 'Cuda 383, 4spd
71 'Cuda 383, auto
Offline GoodysGotaCuda
Re: Lifting front end of e-bodies, safest way?
« Reply #1 on: June 18, 2016 - 04:36:05 PM »
Floor jack under the Kmember, jack stands there around the front frame bump stop
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: June 20, 2016 - 09:53:31 AM »
 :iagree:  Be sure that the jack does not go in too far on the K-member or it will slip and possibly hit your oil pan.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: June 20, 2016 - 01:11:18 PM »
If I am putting the front up for any extended peroid of time I always use the front frame to support the Cuda. It will be the area just under the drivers and passengers feet area.
« Reply #4 on: June 20, 2016 - 01:38:42 PM »
Quote
 :iagree:  I place them on the front frame rails directly in front of the torsion bar x-member.  Just make sure the stand is on a flat area of the rail...not where it starts curving up into the engine compartment.
Offline bc3j
« Reply #5 on: June 20, 2016 - 03:14:48 PM »
That's exactly where I place mine, but I always leave the jack resting against the K member because I worry about the engine weight causing a slight droop because the car is a unibody. Never worried about that on a full framed car. Am I being a little paranoid here?
« Last Edit: June 20, 2016 - 03:18:16 PM by bc3j »
