Author Topic: Carpet  (Read 983 times)
Offline ct440rod
Carpet
« on: June 19, 2016 - 03:58:46 PM »
When installing carpet is there a tool to make nice round holes for installing seats or do you just use a razor blade and go at it ? ?
thanks
Offline YellowThumper
  • I left the snow for this?
Re: Carpet
« Reply #1 on: June 19, 2016 - 04:19:30 PM »
Have not tried it but have have heard to use a soldering iron to make the hole.
Offline Fern
Re: Carpet
« Reply #2 on: June 19, 2016 - 04:20:15 PM »
I used a steel punch. I heated it up with a soldering torch and then made the holes while it was red hot. Made great holes and the thread dosent run since it's fused back together.
Re: Carpet
« Reply #3 on: June 19, 2016 - 05:08:18 PM »
I cut with a utility knife.  No issues.  Carpet has been there 20 years. Getting replaced this year cuz of age. Not because it came apart where i cut it
Offline Katfish
  • 70 Challenger
Re: Carpet
« Reply #4 on: June 19, 2016 - 05:41:18 PM »
Soldering iron works nice, makes a good hole and "cauterizes" threads.
Offline Racer57
Re: Carpet
« Reply #5 on: June 19, 2016 - 05:53:03 PM »
Soldering Iron for seat holes and for the screws that hold down the chrome shifter boot ring, I use a propane torch and heat up an ice pick or nail held with vice grips
« Last Edit: June 19, 2016 - 05:55:22 PM by Racer57 »
Re: Carpet
« Reply #6 on: June 21, 2016 - 03:48:32 PM »
Unlike your success I used a utility knife and as I was bolting pieces together one of the threads cut in the screw and ruined my carpet...
Soldering iron now or heated up punches as others have noted.
