Author Topic: 65 amp vs 100 amp alternator  (Read 4828 times)
Re: 65 amp vs 100 amp alternator
« Reply #15 on: June 24, 2016 - 08:32:39 PM »
Back in the 80's I was having an issue & traced it to the disconnect along the passenger side valve cover. (earlier models don't have a disconnect there).
The larger Black wire that carries the alternator charge back through the system was burned..At the time I wired around it but have since replaced the terminals.
Look there & also where the Black wire connects at the Bulkhead.. I found mine was corroded at the Bulkhead, cleaned it up & put some dielectric grease on it...So good so far but I'm gonna do the 8-guage wire bypass at some point to take the load off of the ammeter.
On another occasion my headlamps would dim & with the blinker on you could see the ammeter jump to discharge at idle.. I went on a campaign to clean every terminal & ground to body & engine under the hood, today I would use dielectric grease as well.. worked like a charm..
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #16 on: June 24, 2016 - 10:15:09 PM »
Wade......My headlights dim and my ampmeter pulses with my blinkers also. My electrical system needs some TLC.  I do have a new battery as of last week.   Maintenance never ends.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #17 on: June 25, 2016 - 04:10:28 PM »
Mine does the same thing and all the wiring is new. I think it's just how these things are.
« Reply #18 on: June 25, 2016 - 04:16:23 PM »
To some degree but not far off center... we that have fought the gremlins along the way have seen it worse & better...
I read often of folks wanting to throw new stuff at a problem that they think they have when it's either not a problem or there's simple answers that may resolve the issue. (don't wanna diagnose usually)
The charging systems worked well enough back when so there's no reason they shouldn't be capable now.. given your haven't loaded it down with extras that is...   :thumbsup:
« Last Edit: June 25, 2016 - 04:17:56 PM by Bullitt- »
« Reply #19 on: June 25, 2016 - 06:52:30 PM »
That is the way a stock e-body is.
Offline Katfish
  • 70 Challenger
« Reply #20 on: June 25, 2016 - 09:14:55 PM »
I bought one of these off Ebay for a voltage meter. Plugs into the cigar lighter socket. I only plug it in when I'm in the car. One of these days I'll change the hot wire to a switched source.
I have this also, works well.  Just wish I could find 1 that is small enough to allow the ashtray to close.
« Reply #21 on: June 25, 2016 - 10:43:08 PM »
Ck this ... could mount with adhesive about anywhere
https://www.amazon.com/Koso-North-America-Super-BA024BOO/dp/B0041QJQNQ
or with a little creativity...
https://www.amazon.com/Cigaretter-Lighter-Marine-Voltmeter-Digital/dp/B00JVJFBQY?ie=UTF8&*Version*=1&*entries*=0
just the meter .....maybe where that seat belt warning fixture goes....hmmmm
https://www.amazon.com/Mictuning-Digital-Voltmeter-Waterproof-Motorcycle/dp/B013HZC24Q/ref=sr_1_3?ie=UTF8&qid=1466909703&sr=8-3&keywords=DC+Voltmeter+Digital
« Last Edit: June 25, 2016 - 10:56:44 PM by Bullitt- »
