Author Topic: antenna direction  (Read 883 times)
Offline culp71
antenna direction
« on: June 24, 2016 - 10:54:44 AM »
71 cuda, front pass fender antenna mounting, which direction should the main body be mounted. I would think since its a 90 degree body, setup should be pointed towards the back?
« Last Edit: June 24, 2016 - 10:59:11 AM by culp71 »
Offline Racer57
Re: antenna direction
« Reply #1 on: June 24, 2016 - 11:51:32 AM »
Point the coax towards the back or the opening that leads to the radio.
Offline culp71
« Reply #2 on: June 27, 2016 - 01:16:30 PM »
got it,
2nd question, with the antenna extended it looks ridiculously long...
does not even clear my over head garage door, do most remove the mast
or leave it collapsed most/all of the time.
Offline Fred
« Reply #3 on: June 27, 2016 - 01:56:06 PM »
I think there is an optimum length for FM radio waves.  Maybe 31" ?  I forget.  Any longer doesn't help with signal clarity.  Hope this helps.
