Author Topic: Selecting paint color for 70 AAR lemon twist  (Read 2621 times)
Offline RAEsAAR
  • Newbie
« on: June 24, 2016 - 07:26:52 PM »
Just about 3 week away from painting the underside on the total restoration project.  original color is lemon twist.  looking for help on getting a bit more pop in the factory color...help please
Offline FY1Cuda
Re: Selecting paint color for 70 AAR lemon twist
« Reply #1 on: June 24, 2016 - 07:40:59 PM »
We thought we wanted a little more pop too because the paint chips looked a little boring.  We ended up going with (Dupont) FY1 Lemon Twist, and when the whole car is that color, I think it pops.  Very happy we kept the stock color.
Offline anlauto
« Reply #2 on: June 24, 2016 - 08:30:13 PM »
You have a FY1 AAR and you want to paint it a non factory colour for a little more "pop" ?
That pop might destroy any future value to an original car. :2cents:
Offline GoodysGotaCuda
« Reply #3 on: June 24, 2016 - 10:36:37 PM »
Agreed.
Perhaps add a clear coat to it?
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #4 on: June 24, 2016 - 10:39:24 PM »
I agree with Alan.
Keep it lemon Twist.
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #5 on: June 25, 2016 - 01:04:17 AM »
Lemon twist AAR  it will pop no problem at any time of the day What a great colour .  :money:
Go 4 a spin Ya Why Not.
Offline Cuda Cody
  • Vancouver, WA
« Reply #6 on: June 25, 2016 - 10:46:35 AM »
I think he is wanting to paint it Lemon Twist, but wants to make sure it has pop.  The color itself is one of the hardest to get right.  When I mean right, I mean close to the original without looking to bright or pale.  Kinda like FC7 Plum Crazy.  FC7 and FY1 are really hard to spray right.   The secret is all with how it's painted.  I can take the same factory PPG Lemon Twist mix and paint it so it looks bright or change the way I spray and it looks pale.  It's all in how it's application technique, what it's applied over and how many coats.  If you read the spec sheet for PPG Lemon Twist (to get the correct shade) it calls for it to be placed over a white sealer base and to use 2 to 3 coats.  I've found that 2 coats over white sealer leaves the color a little on the bright side and 3 coats is too pale and 4 coats is all wrong.  But only using 2 coats runs the risk of seeing stripes and doesn't have enough coverage.  This is using a 1.3 tip Sata RP which puts down a lot of paint for high end paint jobs.  For example, if using a Iwata Supernova gun it would lay down a little less paint and 3 coats might be closer to right.  The gun, speed, air pressure, and distance it's sprayed all play a HUGE factor in how it will look (the tone and shade).  I had to slightly adjust the mix to get that 2.5 coat correct look after 4 coats.
So what I'm telling you is have your painter do some VERY specific spray outs over the exact sealer color you will be using.  Send me your phone number and I can talk you through it.  Or I can talk to your painted and give him some tips on how to get the right color.  I'll even share with him my custom mix that makes it a dead on match at 4 coats.
Offline anlauto
« Reply #7 on: June 25, 2016 - 11:12:45 AM »
Okay...after re-reading the original post I guess it could be construed as wanting to get the original colour correct....I thought he wanted a yellow with more pop then FY1  :banghead:
Offline Cuda Cody
  • Vancouver, WA
« Reply #8 on: June 26, 2016 - 03:26:48 AM »
You might be right.  He probably wants a FY1 yellow with more pop then original.  The original color is not as bright as most people think it is.  It's a great color, but it's not a super bright in your face yellow.  It's a perfect blend of bright and mellow.
Offline kissalien
« Reply #9 on: June 26, 2016 - 11:21:19 AM »
Exactly right.
Offline headejm
« Reply #10 on: June 30, 2016 - 02:54:15 PM »
Cody, tried to PM you about tips for spraying FC7 but says your inbox is full. Looking for similar tips about FC7. Thanks.
