Author Topic: Emblem  (Read 2151 times)
Offline ct440rod
Emblem
« on: June 25, 2016 - 07:28:35 AM »
Putting 70 Challenger r/t together. I bought hood emblems about 20 years ago when I went to put them on they only had two studs and there are 4 holes in hood ( 440 magnum ) and it looks small to me. 6 inches long and 1/2 letter height. P/n 2998802. I'm thinking these emblems are not the right ones for bulge hood. Thoughts ?
thanks
Offline anlauto
Re: Emblem
« Reply #1 on: June 25, 2016 - 07:52:36 AM »
Correct emblem, but too many holes in the hood. Should only have two per side :2cents:
Offline 1 Wild R/T
Re: Emblem
« Reply #2 on: June 25, 2016 - 09:51:14 AM »
Offline ct440rod
Re: Emblem
« Reply #3 on: June 26, 2016 - 07:59:12 AM »
Mid 70's I put a 426 hemi emblem on hood. Hard to believe it had more studs.
Offline anlauto
Re: Emblem
« Reply #4 on: June 26, 2016 - 09:17:21 AM »
I believe it would only have had more studs if it were a factory shaker emblem.....however I'm not to sure on the Dodge emblems, more familiar with the Plymouth cars...
Offline hato
Re: Emblem
« Reply #5 on: June 26, 2016 - 11:14:58 AM »
Don't the six pack hood emblems have 3 studs ?
70 FY1 challenger rt/se  440 U code 727 matching numbers power everything rear defogger
70 ff4  gator grain top t/a
Offline anlauto
Re: Emblem
« Reply #6 on: June 26, 2016 - 12:05:03 PM »
Yes I believe you're right and I'm very wrong....Just looked at pictures of my 71 440+6 Challenger and it had three holes.
Sorry...I'll go crawl under a rock now
Offline 1 Wild R/T
Re: Emblem
« Reply #7 on: June 26, 2016 - 12:20:14 PM »
Hemi & Sixpack had three posts which didn't match the spacing of the two holes so adding a three post emblem gets you four holes..... Which is where your are today......Break out the welder......
Offline BS CUDA
Re: Emblem
« Reply #8 on: June 26, 2016 - 04:51:40 PM »
I just pulled my Cuda 440-6 emblems off today an replaced with Cuda 440 emblems and both had 2 posts with identical spacing. Easy swap.
Offline anlauto
Re: Emblem
« Reply #9 on: June 26, 2016 - 04:57:35 PM »
Yea...that's where I went wrong....I'm a die hard Plymouth guy and was thinking of Cuda hood emblems not Challenger... :banghead:
Offline ct440rod
Re: Emblem
« Reply #10 on: June 27, 2016 - 07:37:14 AM »
Boy that suc_s . . car is back from paint shop and I have a extra hole . .
Offline anlauto
Re: Emblem
« Reply #11 on: June 27, 2016 - 07:41:00 AM »
My guess is it's not covered by the emblem ?
You could always use the much larger B Body 440 Magnum emblems :dunno:
Offline hato
Re: Emblem
« Reply #12 on: June 27, 2016 - 03:40:39 PM »
 you could try cutting the studs as last resort if you can position it to cover all the holes and use double side tape. It won't be like exact as the factory but I wouldn't be comfertable using a welder next to fresh paint
