Author Topic: Hard starting  (Read 4473 times)
Offline rattlesnake
  • Rattlesnake
Hard starting
« on: June 25, 2016 - 10:20:01 PM »
Hi y'all,
I have been having hard starting issues when warm ever since I built the car. Here's the rundown. 70 barracuda, 440, approx. 10.5 to one compression, gasket matched and polished 906 heads, big motha thumper cam, electric fuel pump, 850 DP Holley, unilite distributor, dougs 2" headers, team G manifold. Now the problem, starts right up with 4 accelerator pumps when cold. Runs like a demon at all times and is very dependable and sounds great, it idles fantastic. However when I shut it down and the car sits for 15 or 20 minutes it acts like it is flooded on restart. I have to press the pedal all the way to the floor and hold it while cranking for 15-20 seconds. It always starts back up after cranking. If it sits for a short while like 5-10 minutes this doesn't happen. It does not happen when it's cold or even after sitting for an hour or so. Very puzzled.
« Last Edit: June 25, 2016 - 10:22:46 PM by rattlesnake »
keep honking I'm reloading
Offline 73440
Re: Hard starting
« Reply #1 on: June 25, 2016 - 10:40:51 PM »
Sounds like the fuel may be getting too hot at the carb.
Have you pulled the air cleaner when this happens, you can somrtimes hear the fuel boiling.
Check the routing of the fuel lines away from heat.
Insulate the fuel lines.
DEI has fuel line insulation products.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Strawdawg
    • Vortex Buicks
Re: Hard starting
« Reply #2 on: June 25, 2016 - 10:57:49 PM »
and put an insulator\heat shield under the carb
Offline 73440
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
Re: Hard starting
« Reply #4 on: June 26, 2016 - 12:00:10 AM »
I had to drill the throttle plates in my 850. Made a real improvement in starting.
2011 Kawasaki Z1000
Offline cudabob496
Re: Hard starting
« Reply #5 on: June 26, 2016 - 01:23:40 AM »
home-made heat shield. Just cut some sheetmetal so that it will
snug up against the carb. There is one in back of carb to.
2011 Kawasaki Z1000
Re: Hard starting
« Reply #6 on: June 26, 2016 - 07:42:50 AM »
Isn't that for idle quality? How would that affect starting?
:iagree: x2
I had this problem with an edelbrock rpm manifold. Pop open the hood as soon as you stop, remove the air cleaner, and look down the primary bores. On mine I could see fuel wetting down the throttle plates.
I don't seem to have the same problem with the street dominator manifold but and insulator/shield is still on the 'to do' list.
« Last Edit: June 26, 2016 - 07:47:44 AM by dodj »
Offline cudabob496
Re: Hard starting
« Reply #7 on: June 26, 2016 - 01:47:17 PM »
drilling the throttle plates gave a big improvement
in starting, especially when engine was hot, and had been shutdown, like
at a gas station, and when I tried to restart 5 minutes later. It also
helped off idle acceleration from a stop.  The new carbs have added
an adjustment valve (idle bypass valve) that performs the same thing as the drilling
the throttle plates does.
Why it makes starting easier, I'm not sure,other than its
giving my engine more air when it needs it.
« Last Edit: June 26, 2016 - 04:13:53 PM by cudabob496 »
2011 Kawasaki Z1000
Re: Hard starting
« Reply #8 on: June 26, 2016 - 10:47:24 PM »
Even that rubber line around that distributor gets fuel hot, Around the alternator or anywhere other then away from factory practicly. You can't even touch a distributor, head, alternator or anything else once it gets hot. Then you have modified exhaust or non vented exhaust.  vent it correctly, keep the fuel filter down low and where it catches road breeze also little block heat. stay as far from your alt and dizzy as possible with your fuel. Also if ya need one, an insulator for carb if ya need to. Then go play. Over 40 years and 100 or more cars for my toys, I actually never had that problem. But I have always avoided heat. It bites. Small tube headers are killers since they can not disipate heat and it stays above in the engine bay.
I have 2 carbs 800 hp dyno'ed 95 degree heat running on 93 octane on a stock vent system good fuel source and away from the heat. it idles in the track good to, but isnt your question.  Maybe this helped or not?  I don't know. I have been on much for health reasons, but I do build nothing but Mopar.
Offline cudabob496
Re: Hard starting
« Reply #9 on: June 27, 2016 - 02:49:34 AM »
I think that hard starting due to vapor lock, or hot fuel,
is not common, compared to the more likely scenario
that the carb is not adjusted or functioning properly for
easy starting.
2011 Kawasaki Z1000
Offline dano73
  • Purple people eater
Re: Hard starting
« Reply #10 on: June 27, 2016 - 12:02:32 PM »
Yeah I had the exact same problem on a cutlass I used to have it was great unless it sat for like exactly 15 to 20 minutes when hot turns out the gas is boiling as some other members mentioned I put in a spacer made by edelbrock between carb and manifold I got the thickest one they had think it was a one inch the increase in height barely fit under hood never had the problem again now my challenger will turn really slow if the timing is a bit to advanced on a hot shut down. I retarded just a bit and it's fine now
Offline 734406pk
  • Andy
Re: Hard starting
« Reply #11 on: June 27, 2016 - 11:10:58 PM »
Don't forget to block off your exhaust crossover passages if using a Cool-Carb insulator.
Offline john h
Re: Hard starting
« Reply #12 on: June 30, 2016 - 01:15:57 PM »
I had the same issue on a bone stock 360 Crate motor with Small 600 CFM Eddy carb.  Small tube headers.  As soon as I replaced that with EFI, the problem magically went away. I thought I was losing crank Voltage too and that was causing issues with the Ignition control.    I now believe the fuel was boiling out.  The EFI always shoots some amount of fuel at start up.  a warm or hot start gets different amounts of "prime" fuel.  it also has "crank" fuel  My EFI also controls spark so it retards it back to 10* at crank.
John
John
73 Cuda
360 Crate motor
FiTech Fuel injection
727 Trans (wishing it had Over Drive)
Offline cudabob496
Re: Hard starting
« Reply #13 on: June 30, 2016 - 05:35:46 PM »
there are ice/water buckets to keep fuel cold
2011 Kawasaki Z1000
Offline cudabob496
Re: Hard starting
« Reply #14 on: June 30, 2016 - 05:38:43 PM »
2011 Kawasaki Z1000
