I think you may have solved my problem, the 4 speed is not original, was automatic, the brown wire from the relay goes directly to the starter solenoid, When I pilled on the wire to make sure of the direction it took and then hit the key, it started, then no go on the second wiggle of the wire, but a start on the third attempt. Must be shorted wire or loose on the solenoid, I will let you know what the exact problem was. Thanks for pointing me in a direction Chryco Psycho, much appreciated.
