Author Topic: Alternator  (Read 1063 times)
Offline cudabob496
Alternator
« on: June 26, 2016 - 06:05:16 PM »
so is it better to have a one wire alternator, with an internal voltage regulator?
2011 Kawasaki Z1000
Offline johannes
Re: Alternator
« Reply #1 on: July 06, 2016 - 11:55:20 AM »
The answer depends how you define "better".
This solution WILL WORK, and be robust !!!..there will be wires "left over" in your el.system do you care ?... I don't....
More importantly, our weak links are the bulkhead connectors.
If you perform a search, you will find info on bypassing the   amp meter , which indeed is a smart move.
Also replace amp meter with Volt meter can ealisy (and cheaply) be done for people who are not ALL ORIGINAL DIE HARDS.
The info is a quick search away....
Re: Alternator
« Reply #2 on: July 06, 2016 - 12:27:22 PM »
The problem with a 1 wire setup is where you reference the system voltage.  You could connect the "sense" wire directly to the output stud on the alternator.  However, that doesn't take into account any voltage drop in the wiring and can give a false reading.  The "sense" wire should be connected to the battery or the stud on the starter relay.   This way, it is sensing actual battery voltage.
Re: Alternator
« Reply #3 on: July 07, 2016 - 12:24:18 AM »
Also if your reg fails you need a whole new unit
Offline brasil
Re: Alternator
« Reply #4 on: July 10, 2016 - 05:28:59 PM »
what chryco said...     One wire is fine..as long as it works...    The "Oldfashioned " alternator is my favorite..
Greetings Juergen
