Author Topic: Moog offset bushings....  (Read 4486 times)
Offline Mpdlawdog
Re: Moog offset bushings....
« Reply #15 on: July 09, 2016 - 04:07:31 PM »
Getting ready to do this...my instructions say to make sure they are both arrows are towards the ball joint???  Which is right??
Offline rUNCHARGER
« Reply #16 on: July 09, 2016 - 04:47:11 PM »
To get more caster you do them in and out as stated above.
Sheldon
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #17 on: July 10, 2016 - 12:08:23 AM »
Install them opposite of the instructions they came with, or exactly like the pic I posted.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #18 on: July 11, 2016 - 02:55:20 AM »
was confusing at first but he's right.
Offline Mpdlawdog
« Reply #19 on: July 11, 2016 - 12:46:11 PM »
OK thanks guys.....
Offline jhaag
« Reply #20 on: July 11, 2016 - 02:42:16 PM »
the reason the instructions say, (install both outwards), is these were produced as crash parts, to help with alignment after crash repair. they were not produced to be used as we use them. (to increase caster) hope this helps.   :2cents:
love 70 Challengers
Offline js29no
« Reply #21 on: July 11, 2016 - 03:31:42 PM »
The left side of my cuda didn't want to give enough caster, looking at the specs it was deter-mend the front of the tower was in. I have use of A chief EZ liner, so I clamped her down used A grade 8 bolt and washers and gave it A pull. sent it back to the alignment shop and WA-la. :2cents:
Offline Mpdlawdog
« Reply #22 on: July 24, 2016 - 01:18:00 PM »
Oh....well I called qa1 they have never put the moog offset bushings into their upper control arms...and couldn't say if they will work...I hate being the Guinea pig...but it looks like it doesn't work...unless I'm missing something...
No way those will squeeze up in there with both ends on!!!!  Figures my luck!!
« Reply #23 on: July 25, 2016 - 11:04:08 AM »
The QA1 control arms are already built with additional caster in them, unlike the stock arms. You shouldn't need offset bushings in those to get improved caster numbers.
