Author Topic: Tailpipe problem  (Read 1507 times)
Offline shatar4
  • 71 Challenger
Tailpipe problem
« on: June 27, 2016 - 08:53:08 PM »
I ordered a Magnaflow  kit #15852 and as I was mocking it up and I got to the tailpipes and found out they dump at the back corners. I thought they dump out the tail panel. Has anyone ever ran into this and what did you do? Its a 3" stainless steel exhaust so most exhaust places cant bend me one. Thanks
1971 Triple black 340 Challenger
Offline crash340
Re: Tailpipe problem
« Reply #1 on: June 27, 2016 - 10:33:46 PM »
They mostly all do, I have the same one, the pipe after the over the diff, straight pipe angled at say 30' toward ground, then straightens up to go back, I cut and shut the angled straight section to raise the height of the exit pipe to be more in line with the rear valance, then fitted a set of tips, a bit of work but very possible
Greg
73 Cuda
Brisbane, Australia
Offline shatar4
  • 71 Challenger
« Reply #2 on: June 28, 2016 - 09:30:43 AM »
Is there anyway you could post or send a pic of the finished pipe? Thanks
Offline crash340
« Reply #3 on: June 28, 2016 - 03:56:53 PM »
PM sent,
if you have a look at the pic below, not a good pic, but the welds at the very bottom of the photo edge, is where I cut about 4-5" out of the pipe to raise the bend higher so as I could run the pipe out of the valance, I did install the MF 6x6 race mufflers in that pipe though, makes it harder to see, .
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #4 on: June 28, 2016 - 04:05:46 PM »
Greg
73 Cuda
Brisbane, Australia
