Author Topic: The old carb question  (Read 752 times)
Offline Pimtao
« on: July 02, 2016 - 01:33:26 PM »
Hey, so I'm finishing up my engine right now and it's time to decide what carb I should go with?!
My engine is a stock built 340 with stock intake and heads!
what would you guys recommend? Stock Carter AVS? Or something more modern?
 :canada:
Offline brasil
Re: The old carb question
« Reply #1 on: July 02, 2016 - 03:36:21 PM »
If you have a Spread bore Intake....
Thermoquad ! Hands down
if you have a square bore intake...
Carter AVS
Greeetings Juergen
Offline anlauto
« Reply #2 on: July 02, 2016 - 03:40:22 PM »
He's working on a 1970 so it would be a square bore.
Anybody use those Eldelbrock carbs ?
Offline cudabob496
« Reply #3 on: July 02, 2016 - 05:08:15 PM »
all stock, about 600 cfm
2011 Kawasaki Z1000
« Reply #4 on: July 02, 2016 - 07:58:10 PM »
Carter AVS
Greeetings Juergen
 :iagree: as long as you want to use 50 year old technology
 newer carbs are much more tunable  , Proform & Quick fuel are awesome carbs , even EFI is now available for around $1200 or so
Offline Pimtao
« Reply #5 on: July 02, 2016 - 11:28:59 PM »
I don't wanna go the EFI route! But I was definitely thinking to get a new one!
Offline rUNCHARGER
« Reply #6 on: July 03, 2016 - 05:12:18 PM »
I'm done with carbs. FITech is $995 and as easy as bolting on a new carb. If you must run a carb I would try a 650 AVS.
Sheldon
