Author Topic: 440 Casting numbers????  (Read 4566 times)
Offline anlauto
Re: 440 Casting numbers????
« Reply #15 on: July 06, 2016 - 08:56:57 PM »
Here are the correct 1970-71 manifolds. It doesn't matter what year your block or heads are, they are going to fit the same way.
Offline Wadmin1021
« Reply #16 on: July 06, 2016 - 09:02:05 PM »
And are you running Mopar Performance Valve Covers? That's our issue. We can't find anyone running HP manifolds with Mopar Performance valve covers. We know they will fit clearance wise with stock valve covers but we have the MP valve covers which are a little bigger. Thoughts on this???
https://youtu.be/OEKt5K71CDM
A couple that plays together, stays together!
'71 Plymouth 'Cuda named Claudia w/ 440 4-barrel and TF AT
Offline anlauto
« Reply #17 on: July 06, 2016 - 09:59:45 PM »
I'm sure they may be a little bigger, and it may be a little closer, but they'll still fit.
Offline cv70chall
  • 1970 Challenger
« Reply #18 on: August 16, 2016 - 03:32:13 PM »
Updated.
Gaskets failed under the heat. Looking into why this keeps happening.. UGH
« Reply #19 on: August 17, 2016 - 12:58:35 AM »
Updated.
What type of exhaust manifold gaskets? Fel pro?
Ditch them and get copper gaskets.
I went with SCE gaskets and they are working great.
Also a good idea to Ceramic coat the manifolds.
« Last Edit: August 17, 2016 - 01:00:54 AM by Topcat »
Offline cv70chall
  • 1970 Challenger
« Reply #20 on: August 17, 2016 - 12:21:19 PM »
Fel-Pro, Moroso and the latest victim? The Carbon-X gaskets.
Who makes the copper gaskets? (We're talking valve cover gaskets right?)
Can't afford to remove the manifolds- so it'll have to be brush-applied. Any product you can recommend?
« Reply #21 on: August 17, 2016 - 09:41:49 PM »
Offline cv70chall
  • 1970 Challenger
« Reply #22 on: August 18, 2016 - 02:45:48 PM »
Actually, the Moroso ones I tried were those. Steel core-Rubber.
Melted right away on the back corner area.
