Author Topic: Questions about replacing alternator brushes  (Read 717 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: July 05, 2016 - 10:12:03 PM »
Is it possible to replace the brushes without removing the alternator?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: Questions about replacing alternator brushes
« Reply #1 on: July 06, 2016 - 12:11:41 AM »
Maybe  they are easy to remove , just make Sure you do not lose the isolating washers
Offline brasil
« Reply #2 on: July 22, 2016 - 05:48:21 PM »
if you remove the alternator...  you can change the brushes much easier . Also I would open the alternator and
use a piece of fine sanding paper  to "clean " the copper surface of the anchor  ( where the brushes contact the anchor )  brings your voltage output up a little
Greetings Juergen
