Author Topic: Four Link  (Read 1459 times)
Offline cudabob496
Four Link
« on: July 06, 2016 - 01:31:59 AM »
Is there a 4 link setup for the rear of my Cuda, that loses the leaf springs, and saves a lot of weight??
2011 Kawasaki Z1000
Re: Four Link
« Reply #1 on: July 06, 2016 - 05:31:43 AM »
All 4 links are lighter and use no leafsprings
Offline YellowThumper
  • I left the snow for this?
Re: Four Link
« Reply #2 on: July 06, 2016 - 11:03:54 AM »
I have seen on one of the car shows there is a 4 link setup that is specific to e bodies. A few pieces bolt in and a few of the other pieces the brackets weld in.
Don't recall the brand though.
Offline cudabob496
Re: Four Link
« Reply #4 on: July 09, 2016 - 12:20:52 AM »
thanks, some good info!
2011 Kawasaki Z1000
Re: Four Link
« Reply #5 on: July 09, 2016 - 11:07:24 PM »
Fist there are different 4 links , there are some street versions with limited / no adjustablility
 Then there are true 4 links / back 1/2 the car & redo the rear frame rails & now you have a fully adjustable 4 link .
 Then the issue now you have 250 settings & you need to dial in the one that works on any given day with different conditions . Have fun with that !
 I have found a simple ladder bar / floater assy works far more consistantly , for less weight lose the leafs & go to rear coil over with double adjustable shocks . I had no issues pulling the front wheels with street tires on the street with a ladder / floater assy using leaf springs .
Offline TripleT
Re: Four Link
« Reply #6 on: July 11, 2018 - 10:00:26 AM »
I am just reading this now, and wonder if you have any specifics on what "ladder bar/floater assy" you have.  You probably did it yourself but if there is an after market set up you could recommend I'd love to know.
-Tim
1970 Plymouth Barracuda    2000 Dodge Ram 2500
