Local pick-up or shipping available out of Ohio. Open to reasonable offers on everything.
If you are going to swap meets, I am open to offers for everything as one parts lot as well. Pictures available upon request. Mix of new and used parts.
440 Fan Clutch: $15.00
440 Water Neck: $10.00
440 Distributor Hold Down: $20.00
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket: $30.00
70-71 Mopar Rallye Wheel Center Cap: $3.00
Mopar Front Shock Mounting Hardware Kit: $10.00
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer: $18.00
Mopar Fuel Line Hardware Kit: New, kit is for 3/8” supply line and ¼” return line - $15.00
E-body Torsion Bar Set: 774 / 775 bars - $50.00
Chrome Master Cylinder Cover: $10.00
Mopar Electronic Ignition Module: $10.00
70-71 E-body Wiper Linkage Pivot: $40.00
70-74 E-body Heater / Defrost Vent Duct: $50.00
Floor Heat Shield: 2 sheets – Each approximately 6’ x 4’ - $50.00
70-72 E-body 4 Speed Brake Pedal Pad: $5.00
70-74 E-body Standard Dash Light Bar: $50.00
E-body Rallye Dash Speedometer: $175.00
E-body Rallye Dash Tach: 7K - $175.00
E-body Rallye Dash Clock: $175.00
72 – 74 E-body Rallye Dash Lens: $125.00
70-74 E-body Ash Tray Support: $25.00
71-74 B-body / 71 E-body Rear View Mirror: $20.00
70-74 Barracuda Weather Strip Channel Retainer Trim Set: $80.00
73-74 B-body Outside Mirror Gasket: $10.00
70 – 74 E-body Ignition Switch: Missing connector - $15.00
70 – 74 E-body Key Buzzer Switch: Missing terminal ends - $25.00
70 – 71 E-body Ignition Key Lock: $15.00
70 – 74 E-body Turn Signal Switch: Missing connector - $25.00
Mopar A, B and E-body Upper Steering Column Bearing and Insulator: $25.00
Mopar Window Crank Handles: $10.00
Mopar Late 60’s Interior Door Handles: 2 LH handles - $10.00
Mopar Dome Light Assembly: $30.00
Holley Blue Electric Fuel Pump: $100.00
Mopar Trunk Lid Latch Striker: $15.00
B / E-body Trunk Lid Latch Striker: $20.00
Mopar Trunk Lid Latch: $25.00
70-74 Barracuda Trunk Lid Key Lock Latch Lever Hardware: $18.00
70-74 Barracuda License Plate Light Lens: $10.00
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube: $35.00
71 Barracuda Chrome Grill Taillight Bezel Set: $60.00
