Author Topic: Carb Suggestions  (Read 7382 times)
Offline Winston
Carb Suggestions
« on: June 19, 2005 - 09:48:46 PM »
Hey y'all!
Hope all is well with everyone.  I am looking for suggestions on what carb to use on my '70 340.  I am wanting to buy one that looks and performs well; I have been told that the Edelbrock Thunder Series carb is a good one to use that models the AVS that originally came on the car.   If anyone else has an opinion on this topic, please chime in.  Thanks!
Looking forward to hearing from y'all,
Winston   :D
Re: Carb Suggestions
« Reply #1 on: June 20, 2005 - 03:10:22 AM »
I would use a 750 , my perference i sHolley , the Street avenger works well or the avenger Hp
Offline Grancoupe
« Reply #2 on: June 20, 2005 - 07:31:59 AM »
Holley
Offline Winston
« Reply #3 on: June 20, 2005 - 07:40:09 AM »
Chryco,
I looked on the Holley website and found the numbers are in 670, 770, etc....would you go with the 770?
Do you have to specify that the carb will be used on a Mopar, or are they universal?  Is there a preferable place to order one of these from?
Thanks!
« Reply #4 on: June 20, 2005 - 10:39:02 AM »
get the cheapest price , I would use the 770 , they are universal but you need the linkage adapter 20-7
Offline Winston
« Reply #5 on: June 20, 2005 - 11:24:22 AM »
Chryco,
As you can probably tell, I'm a little wet behind the ears with this restoration stuff.   ;D   I have another question regarding the carb.  This car is being put together basically stock; it is bored .30 over, but the original cam, etc is going back in.  It will only be driven locally for enjoyment...never on a racetrack or anything like that.  Do you think a 770 is overdoing it, or for my needs, will a 670 still perform ok?  I'm asking because I truly have no idea.  Me =  :dontknow:  (on a lot of stuff!!)
I appreciate the time.
Winston
« Reply #6 on: June 20, 2005 - 10:53:42 PM »
I assume you are using the dual plane intake , you ucan get away with a slightly smaller carb on a single plane but not on a dual plane , I would use the 770  , keep in mind the Stock 340 + 6 had 950 cfm with the 6 pack
Offline Winston
« Reply #7 on: June 21, 2005 - 07:48:30 AM »
Thanks for the tip, Chryco.
Is this considered a single or dual plane manifold?
« Reply #8 on: June 22, 2005 - 12:28:42 AM »
That is a dual plane , you can see the runners into the heads are on 2 different levels
Offline Winston
« Reply #9 on: June 22, 2005 - 07:41:06 AM »
OK, thanks.  I learn the terminology one of these days.   ;D
I'm going to go with the 770.
Are these things universal or is there a certain number I need to ask for when ordering?
Offline Grancoupe
« Reply #10 on: June 22, 2005 - 07:44:15 AM »
Sorry if i'm incorrect about this but is that a 2 barrel intake? Can't tell from the picture.
Offline Winston
« Reply #11 on: June 22, 2005 - 08:03:54 AM »
Grancoupe,
This is the 4-barrel intake that came on it.  I think with the orange painted masking tape makes it look like a 2-bbl.
Offline hotrod98
    • Maniac Musclecars
« Reply #12 on: June 22, 2005 - 08:45:46 AM »
I run a 625 Carter AFB on my near stock 340 with a 4 speed. This  carb is no longer available, but Edelbrock has a similar carb, a Thunder Series 650.  My setup has plenty of power and gets 18 mpg on the freeway.  I personally think the larger carbs tend to run a little rich and don't tune well especially near idle i.e. cruise night driving, etc. Both will work, but we all tend to go the hotrod magazine direction and end up overcarbureting. I might be wrong, but you may take a hit in the fuel mileage department with the bigger carb, which wasn't an issue until the gas price increases we've seen this year. Just my 2 cents worth.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
« Reply #13 on: June 23, 2005 - 12:21:14 AM »
the Holley number is 80770
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #14 on: June 23, 2005 - 06:40:27 PM »
i might be wrong on this also.....but 670 and 770 are the CFM which is air flow correct?? if not correct me ...so if the 770 is air flow...not fuel flow....couldn't you just swap smaller jets in to lean the mixture if larger carbs tend to run rich which then will up the mpg ?not trying to be a smart ass i jsut haven't messed with carbs all that much and am still tring to figure stuff out...Also isn't there a fine line between having to small of jets and to big of venturas(sp?) which then would make the car run real lean??
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
