Author Topic: carb question for a 383 stroked to 426  (Read 965 times)
Offline kato
« on: July 06, 2016 - 02:33:56 PM »
hi guys
i got my engine rebuilt. the old carb is a quick fuel hr 680 vs...the engine is now a 426..m1 single plane..edelbrock performer heads..msd ignition.. comp cams 249-21-225-4..hp is 495 and tourq is 474..want it to be streetable but go like when when i need it :working:
what kinda carb do you guys recommend?
« Last Edit: July 06, 2016 - 04:23:58 PM by kato »
Offline HP_Cuda
  • Mopar or No Car!
Re: carb question for a 383 stroked to 426
« Reply #1 on: July 06, 2016 - 02:46:36 PM »
Somewhere around the 750-850cfm range.
Offline cudabob496
« Reply #2 on: July 06, 2016 - 03:03:51 PM »
Holly Ultra DP 750
2011 Kawasaki Z1000
Offline kato
« Reply #3 on: July 06, 2016 - 06:43:52 PM »
so i did a compromise..i just ordered a quick fuel 780 vac secondary...i am on the street way more than the strip...wanna keep it well mannered cruising around
Offline cudabob496
« Reply #4 on: July 06, 2016 - 07:02:34 PM »
How do I know if a vacuum or mechanical secondary carburetor is best for me?
For street cars, the vacuum secondary carburetor works best on mid-weight or heavyweight cars with an automatic transmission. They are more forgiving than a double pumper is because they work by sensing engine load. The mechanical secondary carburetor is best on a lighter car with radical camshaft and a lower gear and manual transmission or on a car that is going to be used for racing purposes. Here are some additional resources for you to see on Holley TV. Overview Of 4150 Vacuum Secondary Carbs Click Here To View. Overview of 4150 Mechanical Secondary Carbs Click Here To View.
2011 Kawasaki Z1000
Offline kato
« Reply #5 on: July 31, 2016 - 10:19:35 PM »
this 780 vac quick fuel works nice  not as quick on the bottom but pulls wayyyy harder after 3800 rpm...i like this lots better...lol
