Author Topic: Exhaust Hangar Question  (Read 3500 times)
Offline YellowThumper
  • I left the snow for this?
Re: Exhaust Hangar Question
« Reply #15 on: July 07, 2016 - 07:36:32 PM »
I have an all original body and paint 74 Challenger. Have had it since 83.
Base model 318 car.
Original exhaust was already changed to headers when I purchased it.
There is a witness of a similar sized bracket on passenger side frame rail. That said, I most likely had the same bracket you have pictured. Same bolt thread on drivers side rail but never used. It is covered in undercoat.
Always thought the 2 small bolts that protrude thru the trunk (attached to a plate on the trunk inside) were insufficient for a exhaust pipe hanger. I suspect now they are a mount for the heat shield. With the hanger mounted to the frame.
Offline 73_Cuda_4_Me
« Reply #16 on: July 07, 2016 - 09:37:40 PM »
The 2 bolt thru-trunk mounts are actually rear muffler hanger brackets...
Here is some info I have from 73 parts book, just for information... and nothing here resembles the frame offset bracket we discussed... gotta love it!
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #17 on: July 08, 2016 - 09:47:02 AM »
The fact is that not many 72-74 E-bodies are restored to factory spec.  The 70 and 71s have a much larger following and sell for a lot more when done.  It stands to reason that the more popular cars would be the ones that are researched and documented more extensively.  Since most parts will fit all years, no one really cared to research the small differences in the later years.  Most people with 72-74 cars just build them the way they want and don't concern themselves with finding factory correct parts.  I'm glad you are one of the few who appreciate the later cars and want to return it back to stock condition. :thumbsup:
« Reply #18 on: July 08, 2016 - 10:05:41 AM »
Thanks, Burdar... If I didn't have the original engine, I probably would not be as concerned... and while I'm not purchasing date-correct exhaust components and such, I'd like to keep it somewhat close to the way it was coming off the line...
While I would love to have a 70-71 hemi cuda, my budget won't quite support a caviar diet on a chips and salsa income....
 :grinno:
R11 V6X EN2
« Reply #19 on: July 13, 2016 - 09:43:55 AM »
Thanks for the pics.
I do wonder if there is a difference in hangers between Barracudas and Challengers because the exhaust exits in different locations.
« Last Edit: July 13, 2016 - 09:48:20 AM by YellowThumper »
Offline 1 Wild R/T
« Reply #20 on: July 13, 2016 - 09:59:30 AM »
FWIW I parted a couple 73-74 Challengers back in the 80's that had the exhaust brackets hung off the frame rail so it's definitely no Cuda only... I still have a pair of the brackets somewhere... I stumble across them every few years....
« Reply #21 on: July 13, 2016 - 11:01:23 AM »
Thanks, now my brain can move on to other things...
Also I noticed the 73 pics above do not depict the E body exhaust tips. So they may not be factual for our cars.
