Author Topic: is window primer required?  (Read 861 times)
Offline j72440rallye
« on: July 07, 2016 - 08:54:14 PM »
Had to remove the rear glass to change the filler panel between the decklid and the rear glass.  I was reading online that some used window primer on the body and glass prior to installing the 5/16" window weld to the frame and installing the glass.  Some didn't do it and it still worked fine.  What have you guys done that has worked/ didn't work and is there anything that I should pay close attention to?
Thanks!
 :working:  :wavingflag:
Offline js29no
Re: is window primer required?
« Reply #1 on: July 08, 2016 - 11:32:57 AM »
scuff the paint if it is shiny, then brush on the windshield primer. the butal tape will adhere better.
Offline jimynick
« Reply #2 on: July 08, 2016 - 11:59:12 PM »
:iagree:  Yep, what the man said.  :cheers:
« Reply #3 on: July 10, 2016 - 12:16:50 AM »
Great, Thanks for the advice! :thumbsup:
