Author Topic: Heater Hose  (Read 516 times)
Offline dana60
Heater Hose
« on: July 08, 2016 - 01:02:25 PM »
There are two coper pipes that come out of the heater and through the fire wall, one is smaller thane the other in diameter ( see picture ) . My question is, where does the smaller hose go to on the water pump? Is it the one closest  to the radiator or or the one closest to the distributorcap ? Thx
Offline HP_Cuda
  • Mopar or No Car!
Re: Heater Hose
« Reply #1 on: July 08, 2016 - 01:07:09 PM »
Does this help?
Large one is on top, smaller one is on bottom.
Offline anlauto
Re: Heater Hose
« Reply #2 on: July 08, 2016 - 01:16:26 PM »
On a big block it doesn't really matter....Just check the size of the nipples on the front of the engine...could be a chance you have two large ones on the engine.
Offline dana60
Re: Heater Hose
« Reply #3 on: July 08, 2016 - 01:32:44 PM »
I took the nipples off when I replaced the water pump and one is the smaller diameter nipple and one is bigger, just cant remember where the smaller one goes on the water pump? It is a 440 engine. Thx
« Last Edit: July 08, 2016 - 01:47:16 PM by burdar »
