I'm using the powermaster #79091 from Bouchillon Performance. sticker says 75/66 amp (75/50 amp at speed and idle) The testing slip says 66 amps at 2400 rpm and 95 amps at 7500 rpm (alt rpm not the engine)
I know this isn't as powerful as what you are looking at but,
Seems to be working fine, never shows a discharge. Stereo with amp and woofer, A/C, Headlights on relays, Megasquirt fuel and ignition.
But, I would put the biggest I could find that fit if I had to it over again.
Dan
