Author Topic: 70 Challenger RT - EFI 6 Pack Conversion  (Read 66195 times)
Offline 70chall440
Re: 70 Challenger RT - EFI 6 Pack Conversion
« Reply #195 on: November 18, 2016 - 10:27:00 PM »
Thanks
Current Mopar
Past Mopars
Offline marc70challenger
« Reply #196 on: November 18, 2016 - 10:32:45 PM »
Looking good!
Thanks for all electrical diagrams ... I've become obsessed lately with indulging in the juice ....  :woohoo:
1970 Challenger 340 Performance Package
1965 Barracuda - "The Pumpkin"  http://www.cuda-challenger.com/cc/index.php?topic=116471.0
Offline 70chall440
« Reply #197 on: November 18, 2016 - 11:42:06 PM »
no worries, happy to share.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #198 on: November 22, 2016 - 01:06:32 AM »
Finally got the other bracket made, sitting in paint now. Now I move on to the wiring and hopefully get this thing running and driving.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #199 on: November 23, 2016 - 09:19:10 PM »
More bracket work. This is for the fuse panel for all of the switched power requirements.
« Last Edit: November 23, 2016 - 09:22:54 PM by 70chall440 »
Current Mopar
Past Mopars
Offline 70chall440
« Reply #200 on: November 23, 2016 - 09:24:57 PM »
Oh, and yes all of that mess will clean up once I run all of the wires. Need to have all of the termination points established and understand what goes where before cutting...
Current Mopar
Past Mopars
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #201 on: November 24, 2016 - 12:40:18 AM »
Nice work Mike!  :2thumbs:
 :popcorn:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline 70chall440
« Reply #202 on: November 24, 2016 - 12:55:10 AM »
Thanks Randy, it is slow going but I will get it done eventually.  :bigsmile:
Current Mopar
Past Mopars
« Reply #203 on: November 24, 2016 - 06:54:26 AM »
 :2thumbs:   Know what you mean.  Some days it can be 4 hours and it feels like all I did was stand and stare at it.  :smilielol:
Looking good though!
Offline usraptr
« Reply #204 on: November 24, 2016 - 12:06:08 PM »
That wiring is just how mine is currently.  Also need to establish termination points before cutting, bundling and re-wrapping.  BTW, great job on that alternator adjustment bracket.  That should be an OEM item.   Don't suppose you'd want to build me one?   :roflsmiley:
(Edited 8-1-17)
Offline 70chall440
« Reply #205 on: November 24, 2016 - 12:29:05 PM »
About to start actually running and terminating the wiring, just have one more item to install, the 150A fuse for the new #4 alternator charge wire.
I wouldn't mind building you brackets but it is kind of a "one off" deal depending on the vintage of engine, alternator being used, what belt you have or intend to use, etc. My point is that I would hate to spent a lot of time and charge you for something that doesn't work or fit. Do you have a welder? It isn't that difficult to make. I make a lot of my stuff using 1/8th thick flat plate and in this case doubled it up to get the strength I need. I use a lot of "scrap", never throwing anything away. In this case I could have used the factory brackets as they were intended or altered them to accommodate a tension rod which was plan B. After looking at it and having realized I bought those brackets, I decided to go to plan C which is shown here. The other reason for going this way was the orientation of the alternator, I wanted the connections facing the left fender so I could see and get to them. If I would have gone with plan A or B, I was thinking that wouldn't be the case, although now thinking back I could have made it work.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #206 on: November 24, 2016 - 12:30:39 PM »
Oh I definitely know that feeling  :bigsmile: For me its called procrastination... and I will do it without thinking about it; usually in the form of cleaning up the shop or becoming intensely interested in something else...  :bigsmile:
Current Mopar
Past Mopars
Offline Challenger in NC
« Reply #207 on: November 25, 2016 - 10:23:50 AM »
Fantastic work.
Offline 70chall440
« Reply #208 on: November 25, 2016 - 01:18:44 PM »
Thanks.
One more bracket... I had to build one for my new 150A fuse connecting the alternator and the starter relay. I also got the alternator prepped for install. I used one of the horn mounting locations (I only have 1 horn currently -70 RR "beep beep" horn). I made the bracket like the horn brackets with a locating/anti rotation tab which worked out exceptionally well. I got the fuse at O'Reillys (fuse was $4.95) and they had to locate the holder which they did not carry but is on their website, only took about 3 hours to have it delivered to my local store from a hub ($9.95). Very nice unit from Littelfuse, the fuses themselves are called "Mega" and come in a wide variety of amperage ratings.
I tried a variety of routings for the new #4 charging wire but just could not find something I liked; if I tried to run it against the already very crowded firewall with everything else, the cable was/is a tad too short, I looked at running it across the K frame (which wasn't bad) but then decided to run it across the radiator core support where it is almost invisible. I still have to figure out where and how to mount the ECU relay and fuse as well as the ECU main power fuse. I believe these are going to be inside the car.
I need to get some 10g wire to power my new "switched" fuse panel (the one under the MSD box); this will carry the heavy blue and brown wires that used to go to the ballast resistor. I will then run the ECU, MSD and Tach adapter to this panel for hopefully a very clean install.
Current Mopar
Past Mopars
« Reply #209 on: November 25, 2016 - 02:24:41 PM »
Nice and clean looking!  :2thumbs:
