Author Topic: 4 Speed Linkage Setup  (Read 9031 times)
Offline dave73chally
« on: July 11, 2016 - 08:53:23 AM »
So I got my brand new 4 speed from Passon, awesome people to deal with and great product. I received brand new hurst shifter mechanism and rods. I set the operating levers on the trans in neutral, set the levers on the shifter mechanism in neutral then adjusted all the linkages to fit and installed. Should I be able to run through the gears easily at the shifter at this point?
Now at this time, I do not have my z bar/clutch hooked up. I'm asking because there is a lot of resistance at the shifter and I'm concerned if I hooked everything up correctly or not. I'm hoping that once that clutch is installed and engaged, it will allow the gears to free up?
73 Challenger
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 4 Speed Linkage Setup
« Reply #1 on: July 11, 2016 - 09:10:25 AM »
Can you post a pic of how you have the rods connected?
« Reply #2 on: July 11, 2016 - 09:37:39 AM »
I'll take a picture of the linkage in the car tonight to make sure, but this is how it is connected at the shifter mechanism and the reference photo I used for the rest...based on your response, I'm guessing something sounds wrong?
73 Challenger
« Reply #3 on: July 11, 2016 - 09:46:59 AM »
Ah crap, from other reference photos looks like I have 1st and 2nd rod in from the wrong side at the shifter mechanism. Does that sound right? It's hard to make out in the reference photos.
73 Challenger
Offline dfrazz
« Reply #4 on: July 11, 2016 - 09:55:58 AM »
That is possible, but hard to tell without a pic of it installed.  I had my rods messed up and the same result of hard to shift at all.  I looked them up, switched to the correct locations and it was easy to shift so my be is you have them connected wrong.
« Reply #5 on: July 11, 2016 - 10:00:06 AM »
Can you post some pictures of how yours are setup both at the trans and the shifter mechanism? I can't seem to find any great reference photos, specifically at the shifter mechanism.
73 Challenger
« Reply #6 on: July 11, 2016 - 11:19:23 AM »
With everything new & tight it can be difficult to shift but ti should shift smoothly \  depress the clutch will help
Offline dfrazz
« Reply #7 on: July 11, 2016 - 11:31:47 AM »
Mine is a b-body 833 in my '68 Charger so the rods are different. Hope this helps.
Offline jhaag
« Reply #8 on: July 11, 2016 - 12:03:11 PM »
looks correct to me. line up holes in levers on shifter with a drill. all in neutral. should be able to shift thru the gears while on bench. could be smooth or not. just depends on the trans and shifter.
love 70 Challengers
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: July 11, 2016 - 12:21:11 PM »
Should shift without a problem, yes a little stiff but shiftable.
« Reply #10 on: July 11, 2016 - 02:42:18 PM »
Ok so the 1st and 2nd rod at the shifter mechanism, is the rod end inserted from the driver side, and clip on the inside (towards the passenger side)? Same orientation as the 3rd and 4th lever, or the opposite?
Dfrazz's picture shows the pin inserted from the passenger side and clip on the drivers, but is that different because the rods are different for a b body?
73 Challenger
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: July 11, 2016 - 03:27:24 PM »
Had a couple of mins today.
This is how mine is setup, looks like all the stud ends face towards the passenger side.
« Reply #12 on: July 11, 2016 - 03:49:27 PM »
Thanks, that's exactly how mine is setup. I guess I'll wait until I have the clutch hooked up and see if that frees it up.
73 Challenger
« Reply #13 on: July 11, 2016 - 07:28:18 PM »
Here's some pictures of how I currently have it all hooked up:
Just noticed the 3/4 rod is hitting the frame, is this common?
73 Challenger
« Reply #14 on: July 11, 2016 - 08:35:01 PM »
Any harm in moving the rod up to the next hole to help clear where it's hitting the body?
73 Challenger
