Author Topic: 4 Speed Linkage Setup  (Read 9047 times)
Offline dave73chally
Re: 4 Speed Linkage Setup
« Reply #45 on: September 01, 2016 - 06:59:37 AM »
Huh you are running this beast with no fluid  :bricks1:  :22yikes:
Crap, did I destroy my trans? It was never put in gear or moved and stayed in neutral. Only started up once  :faint:
73 Challenger
« Reply #46 on: September 01, 2016 - 08:50:21 AM »
well the input shaft , counter shaft & all the gears on the main shaft are still turning in neutral , only the main shaft is stationary
« Reply #47 on: September 01, 2016 - 08:56:07 AM »
So I guess I'll pull the front cover and inspect? Then fill it with oil, run it for a minute or so and drain it and see if there are metal shavings? Really hope I didn't mangle anything. This is my first time for all of this, sucks all the things I don't know.  :banghead:
73 Challenger
« Reply #48 on: September 01, 2016 - 02:01:08 PM »
how long did you break the engine in for ?
 shavings may not be the issue , one or more of the gears on the main shaft may be galled or seized , that is why the car tried to move on you , that is a massive oooopppp s
 I would not pull the cover , not easy to install again in the car , add oil to the trans & see what happens , I think you will have to pull the trans as 1 or more of the gears on the mainshaft & possibly the main shaft may be damaged now
« Last Edit: September 01, 2016 - 05:34:02 PM by Chryco Psycho »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #49 on: September 01, 2016 - 06:42:33 PM »
Crossing fingers for ya... :popcorn:
« Reply #50 on: September 10, 2016 - 11:27:57 PM »
So here's the update. Thought the driveshaft was spinning free but it wasn't. Pulled the trans out last night and brought it to Jamie at passon this morning. Got there at 8am, by 930am I was out the door with the fixed trans. 1/2 gear was welded to the mainshaft. New 1/2 gear, main shaft and 2 syncros. Cost me a few hundred bucks, Jamie was honest fair and cool about the entire situation. Overall awesome guy to deal with and just conversate. Trans now shifts like butter, going in tomorrow a.m. The price of stupid didn't break the bank and I'm back in action, couldnt ask for more.
Oh and chrycho, spot on with the diagnosis
73 Challenger
Offline HP_Cuda
  • Mopar or No Car!
« Reply #51 on: September 11, 2016 - 02:22:41 PM »
Was the 1/2 shaft done in by the startup or with the original build?  :clueless:
« Reply #52 on: September 12, 2016 - 01:08:23 AM »
Glad you solved the issue , too bad about the damage  :2thumbs:
« Reply #53 on: September 12, 2016 - 10:27:49 AM »
My fault entirely, not anything to do with how it was built. Jamie is a stand up guy, I learned my lesson  :cheers:
73 Challenger
« Reply #54 on: September 12, 2016 - 10:30:43 AM »
Yea, glad it all worked out. Was really cool watching Jamie diagnose the problem, pull it apart, reassemble and have me on my way in under 2 hours. And now I have a mainshaft to build a stool for my man cave! Jamie said "here's your trophy"...don't think I'd call it a trophy but yea  :cheers:
73 Challenger
Offline 73440
« Reply #55 on: September 12, 2016 - 01:38:53 PM »
I have parts like that, chalk that up to learning.
I adjusted the rockers on my Norton after drinking, locknut ended up loosening and adjuster backed off then the pushrod broke the rocker arm.
New valve job and rocker later, it was running like a scalded dog.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline HP_Cuda
  • Mopar or No Car!
« Reply #56 on: September 12, 2016 - 02:35:34 PM »
How about a pic for fun???
 :popcorn:
