Author Topic: Need info, Issue with Rear window track on drivers door  (Read 2338 times)
Offline tman
« on: July 12, 2016 - 04:13:33 AM »
After a car show, my driver side window would not roll all the way up.  After removing the door panel and watching what was going on, I discovered that the light blue colored plastic wedge near the top of the REAR TRACK was loose.  So when I roll the window up, that blue wedge gets jammed and prevents the window to completely close.  Its about 2 inches short of closing.
I took a long screwdriver to put that wedge back into the slot in the rear track.  But it eventually gets loose again.
My question is this:  What keeps that wedge in place?????  The attached photo shows the wedge back where it should be.
Sorry, pic is sideways.
« Last Edit: July 12, 2016 - 04:15:05 AM by tman »
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Need info, Issue with Rear window track on drivers door
« Reply #1 on: July 12, 2016 - 08:02:09 AM »
I believe there is a small spring that suppose to hold up. spring break and that wedge drops. I'll check some used guides.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: July 12, 2016 - 01:16:13 PM »
Funny you mention this as I recently swapped tracks and had to move the spring over with the blue wedge.
Offline tman
« Reply #3 on: July 12, 2016 - 01:21:07 PM »
Oh please find me a spring..  What does that spring look like?  I have searched for some type of fastener at the bottom of my door with a magnet and nothing.  Must have fell out of the drain holes?
Thanks for the assist!
Offline HP_Cuda
  • Mopar or No Car!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: July 12, 2016 - 04:52:02 PM »
Here it is. this one is a little dry as in rusty. If you grab one like Brian posted maybe beneficial.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline tman
« Reply #6 on: July 12, 2016 - 06:55:46 PM »
Ok, that is doable.  Thanks all for your help.
Dave, thanks for the photo.  How long is that spring in the pic?  Same dimensions as the Home Depot spring? Or
HPcuda, I know you sent that link as an example, is that the one I need to order since I don't know how long it is.
« Last Edit: July 12, 2016 - 06:59:28 PM by tman »
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: July 12, 2016 - 07:45:34 PM »
One suggestion is to check out your opposite door for exact size. Might as well replace both then.
My2c
Offline tman
« Reply #8 on: July 12, 2016 - 08:52:39 PM »
Good suggestion, but would like to avoid taking the other door apart.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: July 13, 2016 - 02:00:01 PM »
The one I listed is 1.25" long and it will be very close, you may have to change the bends on the ends but that's it.
Offline tman
« Reply #10 on: July 13, 2016 - 07:04:13 PM »
Thank you!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #11 on: July 14, 2016 - 09:51:53 AM »
1 7/8 over all length
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline tman
« Reply #12 on: July 14, 2016 - 10:22:02 AM »
Thanks Dave!  The spring HPCuda pointed out should work just fine.  Hope I can get that in w/o taking the glass out.
« Last Edit: July 14, 2016 - 10:24:37 AM by tman »
Offline tman
« Reply #13 on: July 23, 2016 - 06:49:54 PM »
Just a follow up.  I got the spring that was recommended and installed w/o having to take the window or track out. It was pretty ez.
Thanks again Mopardave and HPCuda.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #14 on: July 24, 2016 - 12:14:31 PM »
 :2thumbs:
