E-body Parts
Author Topic: E-body Parts  (Read 1742 times)
Offline Claudia
E-body Parts
« on: July 13, 2016 - 02:05:11 PM »
Prices range from $3.00 - $175.00
Shoot me an offer if you are interested in anything.
Pictures available upon request.
440 Fan Clutch
440 Water Neck
440 Distributor Hold Down
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket
70-71 Mopar Rallye Wheel Center Cap
Mopar Front Shock Mounting Hardware Kit
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer
Mopar Fuel Line Hardware Kit: New, kit is for 3/8” supply line and ¼” return line
E-body Torsion Bar Set: 774 / 775 bars
Chrome Master Cylinder Cover
Mopar Electronic Ignition Module
70-71 E-body Wiper Linkage Pivot
70-74 E-body Heater / Defrost Vent Duct
Floor Heat Shield: 2 sheets – Each approximately 6’ x 4’
70-72 E-body 4 Speed Brake Pedal Pad
70-74 E-body Standard Dash Light Bar
E-body Rallye Dash Speedometer
E-body Rallye Dash Tach: 7K
E-body Rallye Dash Clock
72 – 74 E-body Rallye Dash Lens
70-74 E-body Ash Tray Support
71-74 B-body / 71 E-body Rear View Mirror
70-74 Barracuda Weather Strip Channel Retainer Trim Set
73-74 B-body Outside Mirror Gasket
70 – 74 E-body Ignition Switch: Missing connector
70 – 74 E-body Key Buzzer Switch: Missing terminal ends
70 – 71 E-body Ignition Key Lock:
70 – 74 E-body Turn Signal Switch: Missing connector
Mopar A, B and E-body Upper Steering Column Bearing and Insulator
Mopar Window Crank Handles
Mopar Late 60’s Interior Door Handles: 2 LH handles
Mopar Dome Light Assembly
Holley Blue Electric Fuel Pump
Mopar Trunk Lid Latch Striker
B / E-body Trunk Lid Latch Striker
70-74 Barracuda Trunk Lid Key Lock Latch Lever Hardware
70-74 Barracuda License Plate Light Lens
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube
71 Barracuda Chrome Grill Taillight Bezel Set
Offline cuda2cruz
Re: E-body Parts
« Reply #1 on: September 07, 2016 - 06:46:21 PM »
do you still have your rally center cap
Offline Fatback
Re: E-body Parts
« Reply #2 on: September 08, 2016 - 08:48:50 AM »
Do you still have the Mopar Dome Light Assembly and can you send me a picture, thanks
Everett my email is  stephensone@michigan.gov
Offline soundcontrol
Re: E-body Parts
« Reply #3 on: September 08, 2016 - 08:58:04 AM »
Sending you a PM about some parts.
/ Ken
topic=108917.new#new
Offline Claudia
Re: E-body Parts
« Reply #4 on: September 13, 2016 - 08:21:58 AM »
cuda2cruz - Yes, I still have the one center cap disk if you are interested.
Fatback - I just sent you a email with the pictures.
soundcontrol - I just replied to your PM.
