Author Topic: HP Manifold Heat Riser  (Read 1631 times)
Offline Claudia
« on: July 14, 2016 - 03:09:52 PM »
Looking for some advise on the heat riser in the big block HP manifold.  Thinking about either tac welding it open or just removing it completely and welding up the two holes.  Advantages or disadvantages?  Any input is appreciated.
Re: HP Manifold Heat Riser
« Reply #1 on: July 15, 2016 - 12:08:13 AM »
welding to cast really doesn;t work , I have just removed the plate from the cross shaft & left the cross shaft in place though
Offline turbostang7
« Reply #2 on: July 15, 2016 - 11:10:15 AM »
What about cutting it out, then drilling and tapping for a pipe plug?
1970 Barracuda project in the making!
« Reply #3 on: July 15, 2016 - 12:55:14 PM »
can be done
Offline Claudia
« Reply #4 on: July 19, 2016 - 10:16:45 AM »
I have already removed the heat riser so I think I am going to try to tap the holes and plug them.
Offline YellowThumper
  • I left the snow for this?
« Reply #5 on: July 19, 2016 - 07:36:07 PM »
Agree with this route. Suggest to use a standard bolt thread and a set screw. Not a tapered pipe plug because of all the thermal cycling. After plug is installed try a small pin punch to slightly dimple the top thread so plug will not fall out.
« Last Edit: July 19, 2016 - 07:38:31 PM by YellowThumper »
