Author Topic: Can only break it once  (Read 1096 times)
Offline 73440
« on: July 14, 2016 - 10:18:34 PM »
My ac at the house stopped working 5 days ago and the heat index here in Houston has been close to 110 degrees outside with 85 degrees inside.
AC company use at work calls back after 2 days and says we dont wrk on residential.
Ok, time to try to fix myself as funds are low, never pulled an ac unit apart before.
Watched a few youtube videos , bought a couple of capacitors and wired it all back in, I now have ac and saved Im sure a few hundred.
This all relates to cars as such that due to there are a lot of mechanic aspects Ive been afraid to work on due to "never" having done them, if its broke, can I really break it more, or maybe I just fix it and learn something new.
Watchin on here how everyone is diving into new aspects of rebuild, remodel, repair everything is a great motivator also.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Re: Can only break it once
« Reply #1 on: July 14, 2016 - 10:41:48 PM »
Ha!
Kinda like how I approach some stuff at work...Well it's broken now, how much worse can I make it? lol
« Reply #2 on: July 14, 2016 - 11:36:02 PM »
Me too , just get in there & try at worst you buy new anyway !!
Offline CHL2T
  • Handle it, man!
« Reply #3 on: July 16, 2016 - 12:35:46 AM »
I always tell myself, "if it's not broken in half, I can probably fix it"  :roflsmiley:
Offline RCCDrew
« Reply #4 on: July 16, 2016 - 05:17:48 AM »
Google and YouTube are definitely your friends. I always say if you're having a problem, someone else has already had that problem.
Offline solarguy
« Reply #5 on: July 16, 2016 - 08:38:09 AM »
My ac broke last week too,  compressor run capacitor tests bad.  I couldn't find one local on the shelf have one in transit from China from ebay.  Hot as heck here too.  Thankfully, I have window unit picking up the slack.
Offline 73440
« Reply #6 on: July 16, 2016 - 09:39:03 AM »
My capacitors were both mounted horizontal , I think some are oil filled, they should be mounted vertical, may have contributed to the failure.
All I had were fans, but realized 85 degrees was not nice but bearable when the outside is 25 degrees hotter.
There is also the booster kick start capacitor and relay on mine that helps the compressor life.
AC unit is 18 years old, cools well. As my brother says about my vehicles , why dont you get something made in this century.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline RCCDrew
« Reply #7 on: July 16, 2016 - 03:24:46 PM »
My AC went out last year and it was the outside contactor. Be aware of those too.
« Last Edit: July 16, 2016 - 07:02:29 PM by RCCDrew »
Offline Cudakiller70
« Reply #8 on: July 16, 2016 - 04:44:30 PM »
Had a hard shell beetle get inside the AC and the contactor couldn't close. Doesn't hurt to unplug or turn off, then just take a look, but be careful of capacitors.
The above is just my opinion
John Adams
Offline YellowThumper
  • I left the snow for this?
« Reply #9 on: July 17, 2016 - 09:50:24 PM »
Same mentality here about it already being broken.
I have an 02 Dakota R/T and it has the usual rotted of clear coat issue. Going to soon set up and use it as my practice vehicle.  Paint is already "broken" so I cannot screw it up any more.
