Author Topic: Dual Ballast Wiring Harness Convert for Single Resistor  (Read 737 times)
Offline 74Cuda318
« on: July 17, 2016 - 11:50:04 AM »
Is there a 0.8 ohm single ballast resistor that will fit the dual connector? I'm trying to use the .8 ohm msd ballast resistor and blaster coil with a mopar 4 pin orange box ecu.  I don't really want to cut the original harness, but it has some plastic bosses on it that prevent it from connecting to a single resistor.  I guess I could add wires from the connector to the resistor.  What do people typically do in this case?
Thanks,
Michael
Offline 73440
Re: Dual Ballast Wiring Harness Convert for Single Resistor
« Reply #1 on: July 17, 2016 - 12:04:49 PM »
A company like www.molex.com may have connectors to tie the system together.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 74Cuda318
« Reply #2 on: August 18, 2016 - 09:25:53 PM »
Thanks for the reply.  I just used spade connectors.
