Author Topic: Carb heat shield  (Read 726 times)
Offline cudabob496
Carb heat shield
« on: July 17, 2016 - 06:55:15 PM »
I took two 8" by 10" pieces of sheetmetal, a while back, and snug them up to the front
and rear of my 850, at the carb/intake seam, to keep the carb cooler.  Got home today after driving in 90 degree weather,
and used my temp gun to see if heat shields were working.  Average temp of all components near
and under the front heat shield was about 175, while average of front carb bowl temp and other temps in the area above
the front shield was about 135. So, they do work.  Also, the sheet metal is quite polished, so it must be reflecting a lot
of radiant heat.
« Last Edit: July 18, 2016 - 07:00:38 PM by cudabob496 »
2011 Kawasaki Z1000
Offline barnett468
Re: Carb heat shield
« Reply #1 on: July 28, 2016 - 12:38:20 PM »
of radiant heat.
Cool test but did you check carb temp before adding the shield to get an idea of just how much the temps dropped?
I'm pretty sure that Chevy had some cars back in the 60's that came with them from the factory like the 425 hp 427 engines.
« Last Edit: July 28, 2016 - 12:41:23 PM by barnett468 »
Offline jimynick
« Reply #2 on: July 28, 2016 - 11:07:53 PM »
Just saw a 427- 435hp,  3 deuce 'Vette today and it was restored to oem stock and it had one. Silver rag-top 4 speed; what a honey!   :cheers:
