Author Topic: Alignment Question  (Read 1986 times)
Offline CUDA JAS
  • vroooooom!
Alignment Question
« on: July 18, 2016 - 11:29:10 AM »
Hey guys...quick question on alignments.
After installing a rebuilt steering box in my Cuda, the steering wheel is off center (makes sense I guess).
I figure I could just adjust the toe, and get the wheel back to center.  I know the toe may not be perfect, but I should be able to get it close.
Will adjusting the to have any impact on the rest of the alignment?  I would think no, but thought I would check.
Thanks,
Jason
74 'cuda 360/727
Just call me a gearhead!
Re: Alignment Question
« Reply #1 on: July 18, 2016 - 12:58:20 PM »
I would say no.
Offline crash340
« Reply #2 on: July 18, 2016 - 04:01:42 PM »
cant remember if you installed fast ratio arms or not, if you search on here I had "issues" afte installing FR arms ( I think they are C body style now days) with alignment of steering wheel and so on, turns out the FR pitman arm splines are cut clocked half a spline out for an E Body. So, that puts your steering wheel about a 1/4 turn out roughly if you tie rod ends are adjusted equaly, most people simply have one tie rod short, one long and call it done provided toe is set etc. I couldnt handle that in my mind, I had to have equal length tie rod ends, and a steering wheel clocked correctly on the master spline of the steering box. So, I shimmed the steering box, rotated it on the output shaft axis toward the engine, this sorted the problem out for me, it also put the steering column dead smack in the middle of the hole in the firewall so everything lined up perfectly, Im much happier in my mind now :grinno:
Greg
73 Cuda
Brisbane, Australia
« Reply #3 on: July 19, 2016 - 09:24:43 AM »
if you rotate both sides exactly equal amounts even the toe will not change
Offline YellowThumper
  • I left the snow for this?
« Reply #4 on: July 19, 2016 - 07:27:56 PM »
This/\/\/\
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: July 22, 2016 - 09:06:08 AM »
Yep that is my plan!!!
No fast ratio for me...stock replacements.
I can live with the tie rods being different lengths...the steering wheel off center, not so much.
Jason
74 'cuda 360/727
Offline crash340
« Reply #6 on: July 22, 2016 - 06:30:47 PM »
ok cool, then just wind one side in a turn, the other out a turn until your wheel is straight up TDC
Greg
73 Cuda
Brisbane, Australia
Offline GoodysGotaCuda
« Reply #7 on: July 22, 2016 - 07:01:34 PM »
Typically the proper sequence for an alignment is Caster > Camber > Toe. If you are just adjusting Toe, you shouldn't need to revisit Caster or Camber.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: August 10, 2016 - 01:23:22 PM »
Thanks fellas.
Finally found some time to adjust the tie rods...went for a spin and the wheel is much straighter now.  No other issues.
Jason
74 'cuda 360/727
Offline blown motor
« Reply #9 on: August 10, 2016 - 03:55:30 PM »
  No other issues.
Jason
 :roflsmiley: You just wait!
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: August 10, 2016 - 08:37:31 PM »
74 'cuda 360/727
