Author Topic: harmonic balancer problem  (Read 798 times)
Offline 73440
« on: July 19, 2016 - 12:22:23 AM »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline shawge
  • Zoiks!!
Re: harmonic balancer problem
« Reply #1 on: July 19, 2016 - 12:53:35 AM »
 :2cents: The balancer should not wiggle at all and it should not wobble when spinning. It should have an interference fit to the crank nose. I would pull it off and do some measurements.
- Jerry
Offline cudabob496
2011 Kawasaki Z1000
Offline 73440
« Reply #3 on: July 19, 2016 - 01:18:10 AM »
Thanks everyone, thats what I thought, time to check it and most likely have to replace, dang just when I finally got it running well.
Had one go bad on a 351 ford and it had basically disinigrated the rubber.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: July 20, 2016 - 10:50:45 AM »
in your second video are you moving the balancer or the pulley???
I can clearly see something it moving, and that is not a good thing...but I am not sure its the balancer???
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline 73440
« Reply #5 on: July 20, 2016 - 06:30:22 PM »
 Yes it is the balancer moving I have a new one ordered and on the way .
 Bought the nodular iron for now there was a big range of prices on those for sure
« Last Edit: July 20, 2016 - 06:34:42 PM by 73440 »
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #6 on: July 21, 2016 - 04:23:59 PM »
If the thrust brg is bad the whole crank can walk front to back .
Offline 73440
« Reply #7 on: July 21, 2016 - 04:40:41 PM »
I was definetly moving the balancer, hope its not due to the trust bearing being bad.
The balancer must be metal outer mounted to rubberlike substance then an inner metal core, it seemed.
When pulling on ithe outer metal it would flex. It didnot seem like and in and out movement.
New one to be delivered tomorrow and will start with replacement and inspection after that.
I have no info about the engine build or repairs from the PO's.
It is running real good sine the electronic ignition, Revnnator and new Carter carb, needs a little tweaking but wow from before.
Good riddance points.
Thank you all for info and things to check on this repair.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 73440
« Reply #8 on: July 21, 2016 - 05:38:48 PM »
 This will probably also be a good time to install the billet timing marker I bought while things are a little bit out-of-the-way ,
I'm not a big fan of chrome but I do like billet .
 Chrome don't get you home .
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
