Did a search in the www.... MSD voltage flicker seems to be a very common problem.... they are talking about a diode that should be installed within the "small"" red wire from the distributor....
the blue cable that sits on the regulator.... is the same that comes out from the alternator..isn´t it ? so probably I can make a jumper wire from the alternator...to the positive side of the coil ??
Sorry for those "stupid " questions...but I am no electrician... I am a mechanic
Thanks for helping
Juergen
