Another pushrod question
Author Topic: Another pushrod question  (Read 2584 times)
Offline Challenger in NC
« on: July 21, 2016 - 01:09:42 PM »
This is my first engine build so I’d like to run the basic method I used to determine the pushrod length and get some feedback.
1. Adjusted roller tip setscrew so approx. 1 thread was exposed on underside of the roller body.
2. Mounted hydraulic lifter in bore.
3. Used adjustable pushrod (ball on both ends) to measure effective length between roller tip and lifter. I was careful during adjustment to make sure pushrod did not move plunger. Rotated engine to ensure lifter was on heel of camshaft.
4. Took measurements on 4 different valves (2 on each end of head) and arrived at 8.81”. I then added 0.040” to this measurement (provided by Lunati) and came up with a final length of 8.853”.
5. Called Smith Bros., discussed this with sales tech. and purchased a single pushrod (ball and cup) to verify length. Ordered a 5/16” dia. Rod with 0.083” wall.
6. Installed pushrod and backed off setscrew until pushrod just started to deflect lifter plunger. Setscrew now shows no exposed threads (due to 0.040” that was added to length). Rotated engined, checked pattern on valve tip.
Should I have left the setscrew with the 1 exposed thread and let the pushrod pre-load the lifter by the 0.040”?  What else should I check?
I will definitely need to shim the rocker shaft (side to side) to get the roller tips centered over the valves. I will also check other head before ordering a full set of pushrods.
Offline 734406pk
  • Andy
Re: Another pushrod question
« Reply #1 on: July 21, 2016 - 10:18:58 PM »
Typo on line 3? Ball and Ball pushrod?
« Reply #2 on: July 22, 2016 - 12:08:36 AM »
All I had was the ball on both ends adjustable type pushrod. I used that to obtain the effective length and carefully checked it several times.
« Reply #3 on: July 22, 2016 - 12:19:18 AM »
sounds like you are right on to me , he lifter will need preload so adjusted properly approx 1 thread should be visable , other than trying to shim the shafts over the valve tip
« Reply #4 on: July 22, 2016 - 10:06:49 AM »
Thanks. I'll adjust the setscrew back down and also check a few more locations before ordering.
Offline 734406pk
  • Andy
« Reply #5 on: July 22, 2016 - 09:12:40 PM »
I would recommend shimming the rocker shaft to get that contact point on-center of the valve stem first, then measure and order push rods second. Shimming the rocker shaft will change the PR length. Most cup and ball rockers spec 1-3 threads showing, as not to obstruct the lube oil passage to the PR. Remove a adjusting screw and you should see the oil passage inside the rocker.
« Reply #6 on: July 23, 2016 - 01:39:11 AM »
So you are saying to shim the rocker shaft up to improve the wipe pattern on top of the stem?
Offline 734406pk
  • Andy
« Reply #7 on: July 23, 2016 - 06:14:31 PM »
Yes. Moving the wipe pattern to the center of the valves will reduce side loading to the valve stem and guide. The pic of the wipe pattern looks just off center slightly. Here is one link for the shims you need:
 http://store.440source.com/Rocker-Shaft-Shims-pkg-of-30/productinfo/127-1020/
« Reply #8 on: July 23, 2016 - 07:09:44 PM »
Thanks
Offline 734406pk
  • Andy
« Reply #9 on: July 24, 2016 - 08:00:20 PM »
Thanks
 :thumbsup:
 I don't think you will need add very much shim thickness there to get it perfectly centered. I'm not sure which roller rockers you have but most use 3/8-24 adjusting screws. If this is the thread pitch that you have (easy to check with a 3/8-24 nut), 1 turn equals .042" of an inch (1.00/24). Zero lash at one thread showing will yield .042" preload with 2 threads showing for example. No dial indicator needed! Good luck with your engine build! You are doing a nice job there!
« Reply #10 on: July 24, 2016 - 08:11:07 PM »
:thumbsup:
Rockers are from 440 Source so I 'll probably just order a shim set from them. Thanks again for the input.
Offline 734406pk
  • Andy
« Reply #11 on: July 24, 2016 - 08:30:52 PM »
They looked like 440 source with the billet hold-downs. Remember that these rockers need to be shimmed for .015"-.030" side clearance if you haven't already done so. Without shims, they are usually very loose. Here is a link for the shims if needed:
http://store.440source.com/Rocker-Shaft-015-Shims-approx-36-New/productinfo/105-1018/
These work better, they are nice and flat:
https://www.summitracing.com/parts/dcc-3690896
Most engine builds will need 2 packages.
« Reply #12 on: July 25, 2016 - 09:21:17 PM »
I already had the flat shims, but ordered the pedestal shims today.  :thumbsup:
Offline 734406pk
  • Andy
« Reply #13 on: July 26, 2016 - 10:11:54 PM »
Good deal!! Post some pics! :2thumbs:
Offline barnett468
« Reply #14 on: July 27, 2016 - 03:49:51 AM »
No, you want the pattern to be as narrow as possible and the roller will then be wherever it will be on the valve tip.
