I adjusted the rocker shaft using 0.030" shims which I think improved the valve tip pattern. I believe it is more centered if you compare it to the earlier photo. Flat washer type shims were used to take up the lateral play and center the the rocker over the tip. There is between 0.010" and 0.015" of clearance between each rocker and adjacent spacer or hold down.
The rocker ball tip was adjusted to give one thread below the body, and with the 0.030 shims added, the 8.853" long pushrod appears to be very close. With the lifter on the baseline of the cam, the pushrod spins with little effort and is just at the point of engaging the plunger spring. I may need to add in a half turn to the roller tip adjuster? Second bank of rockers still need to be checked. Hope I'm doing this correctly. Shimming and checking the rocker geometry is a royal PITA but realize it must be done.
I also need to pull the oil pan off because every time I rotate the engine, I hear a slight "ping" sound at one point in the rotation.
