Author Topic: It's a Gasket Mystery!  (Read 651 times)
Offline Wadmin1021
« on: July 22, 2016 - 08:26:36 PM »
Our pile of gaskets are dwindling down as we assemble our 440 which will go into our '71 Cuda. We have a few gaskets that came in our kits that we have no idea where they go. Here's the pics! Help please?
https://youtu.be/OEKt5K71CDM
A couple that plays together, stays together!
'71 Plymouth 'Cuda named Claudia w/ 440 4-barrel and TF AT
Offline 1 Wild R/T
Re: It's a Gasket Mystery!
« Reply #1 on: July 22, 2016 - 11:16:20 PM »
The 16 cups are valve seals, I seem to recall you bought new heads, those are part of the heads...
The two rubber L shaped parts are inserts for some rear main self, most engines don't use them...
The O rings are for the distributor & the oil pump... Not all distributors have a groove for the O ring & the oil pump you probably put a new oil pump on which would have that O ring already inside..
The two white rings & the two gaskets with a teardrop shape & two holes are for Air Injection (smog pump) you don't need them
The gasket above is a thermostat gasket for a motorhome...
The big circles are carb to air cleaner use the one that fits...
Offline Wadmin1021
« Reply #2 on: July 23, 2016 - 07:56:33 AM »
Oh wow thanks so much!!!! So follow up questions: 1) Yes we bought new 440 Source Stealth Heads so we will not use the rubber valve seals? 2) Yes, we bought new oil pump... Thanks so much for your info!!!!! Huge help to know we aren't missing something!!!!
