Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
CC Central
Classic Cudas & Challengers Galore sponsored by
CLASSIC INDUSTRIES
(Moderators:
4Cruizn
ChallengerHK
Oldschool
Door Gasket
« previous
next »
Print
Pages: [
1
Author
Topic: Door Gasket (Read 990 times)
ct440rod
Jr. Member
Door Gasket
on:
July 23, 2016 - 05:57:47 PM »
Installing gasket on front door 70 challenger how does the white clips go in ? ? I can get the closed end in put not the open end.
thanks
Logged
Topcat
C-C.com Expert
Member since 9/16/04
Re: Door Gasket
Reply #1 on:
July 23, 2016 - 09:12:55 PM »
I would've never realized these are difficult to figure out.
Are you sure you have the right ones?
The ones that come with the weatherstrip kit are pretty easy to figure out.
This is what I used. No brainer.
http://www.ebay.com/itm/Challenger-Cuda-Door-Weatherstrip-Clips-Mopar-E-Body-25-Pack-45-/131791839684?hash=item1eaf67e1c4:g:zZMAAOSw-W5Uzo45&vxp=mtr
Last Edit: July 23, 2016 - 09:18:36 PM by Topcat
Logged
ct440rod
Jr. Member
Re: Door Gasket
Reply #2 on:
July 24, 2016 - 10:13:11 AM »
Yes those are the hooks . . I thought is was a no brainer also . I inserted hook in to hole and pushed pretty hard put they never lock in. Do they really lock in ? ? I can pull them out after I press them in . .
thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Door Gasket
Reply #3 on:
July 24, 2016 - 10:29:53 AM »
Yes they should lock into place , is the paint too thick around the holes ?
Logged
Topcat
C-C.com Expert
Re: Door Gasket
Reply #4 on:
July 24, 2016 - 10:46:14 AM »
Put the clips on, stretch the weather strip onto each one all the way around each door.
Doesn't matter if they move around. The weatherstripping will pull them tight inside the door.
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Re: Door Gasket
Reply #5 on:
July 24, 2016 - 10:59:33 AM »
Depends on the brand of weather-strip you're using....some are really thick and hard to use....try pushing harder...
Logged
joelson6
Full Member
Re: Door Gasket
Reply #6 on:
July 24, 2016 - 11:06:13 AM »
beat them in with a hammer, that'll always work
Logged
ct440rod
Jr. Member
Re: Door Gasket
Reply #7 on:
July 24, 2016 - 11:11:48 AM »
good idea .. I can use my air chipping hammer .. Should do the trick
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
CC Central
CLASSIC INDUSTRIES
(Moderators:
4Cruizn
ChallengerHK
Oldschool
Door Gasket
