Author Topic: Spark plug wires  (Read 671 times)
Offline cudabob496
Spark plug wires
« on: July 24, 2016 - 04:52:55 PM »
My MSD 8mm wires have about 50,000 miles on them.
Do I need to replace them, or is just an ohm/resistence check
necessary to determine if they are good?
2011 Kawasaki Z1000
Re: Spark plug wires
« Reply #1 on: July 24, 2016 - 07:11:26 PM »
I'd raise the hood in total dark & see if there's any arching...if so time for new.
Offline cudabob496
« Reply #2 on: July 24, 2016 - 07:53:01 PM »
Good idea!
wonder if arching would give higher resistence readings? maybe not.
Maybe an ohmmeter can't detect everything.
You would think over time, due to heat, they would deteriorate.
May just do it anyway, but its a pain cutting them to length, to get exact fit!
2011 Kawasaki Z1000
« Reply #3 on: July 24, 2016 - 08:32:36 PM »
I would start with the ohm meter & see what the readings are but it is extremely low current compared to 80k volt spark
Offline cudabob496
« Reply #4 on: July 25, 2016 - 01:35:03 AM »
ya, good point, lotta opportunity for loses at 80,000 volts
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: July 25, 2016 - 12:01:01 PM »
if you have low resistance (ohms) you have better spark!!!
