Author Topic: cam ??  (Read 1270 times)
Offline Mr. 6pak2go
  • Restore it dont crush it!
cam ??
« on: June 20, 2005 - 05:34:12 PM »
Hey iv got a question about installing my cam!! after the cam is in plce and im installing my sprockets how do i line them up i have a book that says to line up the marks but there are no marks on my sprokets!? i know i turn the #1 piston to tdc and align the oil gallys in the cam with the oil oils in the bearings but what else so i do i do not have a degreeing when i was told its not nessasary to degree the cam for a basic setup what else do i need to know??? also how do i install my destriputer to be somewhat close to being right i relize im gonna have to set my timeing i was just wondering how can i get it close!?? thanks !!
My family, My cars, My guns three things il fight for!!
Re: cam ??
« Reply #1 on: June 20, 2005 - 11:02:39 PM »
if there are no marks on your timing gears return the timing set !!
 there has to be two dots on the gears to line up
 once you have the cam lined up rotate the engine to TDC firing # 1 cylinder & set the dist into place , the rotor sii now pointed at #1 on the dist cap , you can wire in sequence from there , also line up the reluctor with the pick up & then advance the timing slightly it will start from there & you can adjust timing accordingly once it is runnign
Offline Mr. 6pak2go
Re: cam ??
« Reply #2 on: June 21, 2005 - 05:00:58 PM »
thanks chryco!! i found the dots by the way i just needed to scrub some of the dirt off but i got them cleaned up and ready to install thanks!!  :thumbs:
Offline Mr. 6pak2go
Re: cam ??
« Reply #3 on: June 28, 2005 - 06:56:36 PM »
ok i have the engine together!! i installed the distributer today the #1 pistion is at tbc do i turn the distrputer to the number one cylider on teh cap???
Re: cam ??
« Reply #4 on: June 28, 2005 - 11:14:00 PM »
Make sure it is set to #1 firing , you can either move the oil pump drive so the rotor points to #1 or you can install #1 wire where the rotor is already pointing to
Offline Mr. 6pak2go
Re: cam ??
« Reply #5 on: June 29, 2005 - 04:30:17 PM »
if i understand correctly the slot in the shaft can fit eithor way how do i know if im not 180 degrees off??
Re: cam ??
« Reply #6 on: June 29, 2005 - 09:39:50 PM »
pull #1 plug & put your thumb over the hole & bump the engine over until pressure pushes yuor thumb out of the hole & you are on firing stroke your rotor is now pointed at # 1 firing , put the # 1 wire on that tower
dodgetkboy78
Re: cam ??
« Reply #7 on: June 30, 2005 - 12:32:51 AM »
if you havnt turned your engine over, and the dots are still lined up, the rotor should be pointing to the back.
Offline Mr. 6pak2go
Re: cam ??
« Reply #8 on: June 30, 2005 - 04:22:52 PM »
ok thanks guys i think iv got it figured out but if i need more help il holla back!
