Author Topic: 440 motor mount question  (Read 783 times)
Offline usraptr
« on: July 26, 2016 - 12:37:47 PM »
Getting close to installing the 440 engine in my "Cuda and have a couple of questions re motor mount brackets.  FYI, the engine was out of the car and the mounts/brackets removed when I bought it.  I think I've read there is a difference between the right and left side mounts/brackets.  How do I tell the difference?  Secondly, can somebody post a picture of the brackets installed on the engine.  It would be a great help to see how the brackets are oriented/mounted on the block.  I also have several different size bolts, nuts, washers, all mixed together and I'm not sure which ones are used with the  motor mount brackets.  So pictures of the brackets installed on an engine would be a great help.  Thanks.  :feedback:
(Edited 8-1-17)
Offline 73440
Re: 440 motor mount question
« Reply #1 on: July 26, 2016 - 08:59:37 PM »
These are the pictures from when I replaced the driver side motor mount.
https://pisuladevelopmentcompany.box.com/s/83slbvs0r2hk6bob1bz2cbjmjpoxb3en
They are pictures of the old motor mount 440.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline usraptr
« Reply #2 on: July 26, 2016 - 09:13:49 PM »
Thank you 73440.  That was a help.   :2thumbs:
(Edited 8-1-17)
Offline 73440
« Reply #3 on: July 26, 2016 - 09:21:14 PM »
Your welcome, I noticed there is one of the passenger side also.
I so far only replaced the drivers side with the Mancini Mag mount.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline usraptr
« Reply #4 on: July 27, 2016 - 10:44:00 AM »
I'm also using the Mancini Mag mounts.  :2thumbs:
(Edited 8-1-17)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: July 27, 2016 - 02:20:26 PM »
I've used Mancini Mag mounts on 3 cars now and all worked/fit perfectly!
