Author Topic: Starting your car  (Read 771 times)
Offline cudabob496
Starting your car
« on: July 27, 2016 - 10:36:20 PM »
should it be necessary, after pumping the throttle a few times, to have
the accelerator pedal pushed down at all, if the carb is set up right?
2011 Kawasaki Z1000
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Starting your car
« Reply #1 on: July 27, 2016 - 11:13:30 PM »
Press all the throttle pedal all the way to the floor to reset the choke, then a few pumps and should start.  No need to keep the the throttle down.  On a warm start, like a 30 min or so since you shut it off, you should just hold the pedal down 1/2 way on start instead of pump.
Offline cudabob496
« Reply #2 on: July 28, 2016 - 06:53:11 PM »
ok, backed off the idle set screw about 1/3 turn, and did
not touch gas pedal after pumping twice, and car started right up!
2011 Kawasaki Z1000
Offline jimynick
« Reply #3 on: July 28, 2016 - 11:04:03 PM »
Glad to hear it's working for you! I've found that engines, like women, are all different and one will want to be pumped and one won't (no pun intended). It's trial and error until you find what the machine wants/likes. Don't go and ask your wife if she likes to be pumped- or not.  :nono:
Offline cudabob496
« Reply #4 on: July 28, 2016 - 11:37:44 PM »
I agree!
2011 Kawasaki Z1000
