Author Topic: best carpet... legendary,classic ind. ect.  (Read 3763 times)
Offline CudamanTom
Re: best carpet... legendary,classic ind. ect.
« Reply #15 on: August 01, 2016 - 04:38:30 PM »
And I had some trouble getting the sill panels on, and installed so that they weren't catching the door panels when I opened and closed the doors.  Because of the extra thickness.  Extra trimming and a friend helping me push down the sills while I installed the screws were what it took to deal with that issue.
The pain and extra time were well worth it though!
Yes, I got the same mass backed carpet and you're right, the sills took a little bit to get on. I'll add, this is probably the most critical area to pay attention on. If you trim too much, well then the sill won't cover the gap. So the carpet needs to be CAREFULLY trimmed, a little at a time. Then I shaved off a little of the carpet fibers so it would tuck under the door sill. A little work but I am very pleased with the outcome.  :2thumbs:
I know it's hard to tell in the picture what I was talkin about but still, here are a couple pics. :bigsmile:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #16 on: August 01, 2016 - 06:43:16 PM »
ACC all the way, the soldering iron is a great way to get those pesky holes.
I started the hole from the outside then finished on the inside to enlarge the hole. Looks pro now.
 :2thumbs:
Offline CudamanTom
« Reply #17 on: August 01, 2016 - 07:45:01 PM »
 :2thumbs:
I did it the same way B.  :wave: :cheers:
