Author Topic: Broken Motor Mount  (Read 1844 times)
Offline cudabob496
Broken Motor Mount
« on: July 31, 2016 - 08:35:03 PM »
How hard or easy to replace motor mounts in the garage?
2011 Kawasaki Z1000
Re: Broken Motor Mount
« Reply #1 on: July 31, 2016 - 08:48:57 PM »
Not easy but possible , left side huh !!
Offline BS CUDA
« Reply #2 on: July 31, 2016 - 08:51:14 PM »
Offline cudabob496
« Reply #3 on: July 31, 2016 - 09:08:40 PM »
no, actually right side, though I haven't been under there yet,
but its my guess, for last month, when I start the car, getting a loud banging from
the right side, when the engine is initially rocking back and forth.
Once up and running, noise goes away, and the left side is held tight by the torque strap.
But its a stock Mopar motor mount and is 15 years old. Will report what
I find.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #4 on: July 31, 2016 - 09:09:11 PM »
2011 Kawasaki Z1000
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: July 31, 2016 - 10:19:16 PM »
Car on jack stands, disconnect the headers/manifolds from exhaust, a 2x4 across the oil pan edge and raise up the engine just a bit.
Offline cudabob496
« Reply #6 on: July 31, 2016 - 11:57:09 PM »
unhook tranny mount?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #7 on: August 01, 2016 - 02:46:26 AM »
I suppose getting hold of a cherry picker would make it a whole lot easier
2011 Kawasaki Z1000
Offline 73440
« Reply #8 on: August 01, 2016 - 03:01:10 AM »
https://pisuladevelopmentcompany.box.com/s/83slbvs0r2hk6bob1bz2cbjmjpoxb3en
These are pictures from when I did the drivers side replacement changing to Mancini Mag in the garage on jack stands , high jack stands , so I could fit underneath, haha.
I removed the radiator shroud bolts so the shroud would be loose and the fan would not push against it also.
2x6 under the oil pan, the Header was removed as I was replacing it with an exhaust manifold while replacing the starter at the same time , the starter replacement was the initial job. I did not do anyting to the 4 speed tranny mount.
First time I had done a motir mount replacement, went well, take pictures to mount same way with bolts.
Only problem was that I snapped the oil dipstick tube when trying to move it out of the way, its held together now with a screw clamp till the replacement from Roseville arrives this week.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
« Reply #9 on: August 01, 2016 - 12:38:19 PM »
thanks, great info!!
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: August 01, 2016 - 04:57:53 PM »
That will be fun.
 :bigsmile:
