Author Topic: 1970 Big Block A/C parts NEEDED....  (Read 895 times)
Offline anlauto
« on: August 03, 2016 - 07:57:10 PM »
I'm looking for some correct 1970 383 E Body A/C under hood parts. Hard lines, hoses, brackets etc....
Anybody got stuff they're not going to use ?
Contact Alan at anlauto@hotmail.com or PM me here.
Offline 1 Wild R/T
Re: 1970 Big Block A/C parts NEEDED....
« Reply #1 on: August 03, 2016 - 08:29:22 PM »
Brackets are easy... 69-71 Big Block B/C/E body all the same...
Condenser, Steel line from Condenser to Dryer, Dryer, Dryer Mounting Bracket, line from Dryer to Expansion Valve & Expansion Valve Are all pretty 1970 Big Block or Small Block E body.....  The two lines to the compressor are somewhat harder 70-71 Big Block E body or 71 Big Block B body....
You could easily fake the line from the compressor to the condenser with a small block line, the steel part is the same, the rubber hose is about 1" longer on a small block line....    Line from the evaporator to compressor is tougher, it's visually unique & kinda hard to find....
Good Luck!
Offline anlauto
« Reply #2 on: August 03, 2016 - 10:09:27 PM »
Good Luck!
Thanks...actually the 383 bracket that I need is different from the 440 one...I just learned that. :pullinghair:
To make matters worse..I have one set of lines for one car and I want to find the exact same lines for it's sequential brother...  :banghead:
Offline 1 Wild R/T
« Reply #3 on: August 04, 2016 - 12:13:42 AM »
Yes, the rear support brackets are all low deck/tall deck specific...
