Author Topic: Slant 6 oil idiot light ON  (Read 9232 times)
Offline shadango
Re: Slant 6 oil idiot light ON
« Reply #75 on: August 15, 2016 - 08:31:47 AM »
Ooooohhhhhhh.
Ok, then what is the trick to getting off the lower (exhaust) manifold bolts with them together?
For the life of me can't see a way.
Maybe we were just tired. .....
« Reply #76 on: August 18, 2016 - 12:27:08 AM »
flex socket & long extension
Offline shadango
« Reply #77 on: August 18, 2016 - 07:58:41 AM »
Thanks cp.....will try it once the engine is out of the car and on the stand.
Offline YellowThumper
  • I left the snow for this?
« Reply #78 on: August 18, 2016 - 01:15:26 PM »
Check oil pressure with a mechanical gauge.  You have to pull the sending unit out anyway to replace it.  Put a mechanical gauge(borrow one if you have to) on that port and see what you have.  Don't just put the sending unit on and see if the light goes out.  :2cents:
Agreed on this point.
Better and relatively low cost to investigate first. If you assume wrong the potential cost goes up dramatically.
Borrow and or rent a good gauge to test. If that is not an option go buy a cheap mechanical in dash gauge. Don't even bother mounting it. Just Plumb and test.
Definately go with the higher viscosity oil if it has pressure but measures on the low side.
Good luck,
« Reply #79 on: August 22, 2016 - 12:50:03 PM »
Slant 6 and trans for sale here in Thunder Bay. $200. Advertised as running well.
