Hope no one minds me asking this here.....its Mopar, just not a E body....
Over the last couple weeks my son said that the oil light flickered on when going down a hill in his 80 Volare, slant 6...he checked and topped off the level.....wasn't very low but just a half quart/quart maybe.
He went ahead and did an oil change the other day and all was well for several days.
Then today on his way home the oil light comes on. He rechecked the oil level and its fine.
Engine (slant 6, 90k miles) isnt making any more noise than usual.....we wiggled the connector at the pressure switch and the light stayed lit and didnt flicker, so probably not a wiring issue.....the sender doesnt seem to be leaking any oil.....
Pulled the oil filler cap and looked in there with a flashlight while running... doesnt seem to be much splashing or flow as far as I can see at the rocker arm visible thru the hole....
We are gonna get a new switch and hope that is all it is...but that lack of oil splashing around......seems like there would be more? The top of the valve seemed to be wettish but not much else....how much oil should be splashing around up there?
I guess it could be the oil pump if not the switch, or a clogged pickup.....
We were just about getting ready to try and figure out where to mount a real oil pressure gauge too.....LOL
Any advice or thoughts on next steps? Coincidentally ....We JUST had a switch go bad on the barracuda (318) on the way to Carlisle...... and when THAT one went, it started leaking...so it was obvious.....and I have a real guage in that car and we had plenty of pressure.....$8 later at the Carlisle Advanced Auto it was fine.....hoping that is the issue here.....
