Author Topic: Tire combo  (Read 837 times)
Offline shatar4
  • 71 Challenger
Tire combo
« on: August 04, 2016 - 05:22:22 PM »
Has anyone fit a 315/60r15 tire under the back of a 71 Challenger?
1971 Triple black 340 Challenger
Re: Tire combo
« Reply #1 on: August 05, 2016 - 09:32:21 AM »
That is a lotta tire. It both wide and tall.
I have installed but not driven a 295/65r15.  At 30", this is the same diameter as your 315/60r15. With stock 4 count springs it sat up in the wheel well a bit and looked like it had potential to rub when the springs compressed. With XHD or SS springs, you may have enough rate and/or arch to keep it off the sheet metal. It lifts the car up quite a bit and if you are after the vintage drag race vibe, would be a  good stance. However, to  level out the car some you will need a very tall front tire as well as possibly needing to turn the t-bars up some.
Offline shatar4
  • 71 Challenger
Re: Tire combo
« Reply #2 on: August 05, 2016 - 10:32:04 AM »
I do have SS springs which I had re arched 2" over so the back sits up kinda high now.
Offline Road_Runner
Re: Tire combo
« Reply #3 on: August 19, 2016 - 12:25:58 PM »
I'd love to see a pic of it if you do it.  Love the look of huge back tires as long as they don't stick out beyond the upper fender lip.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Tire combo
« Reply #4 on: August 19, 2016 - 01:11:46 PM »
I would think you need a b-body rear and +1-2" springs.
